'69 rear end lubricant - NCRS Discussion Boards
  • Gene T.
    • May 31, 1997
    • 78
    I have a local Corvette friend that needs guidance on what lubricate should he use when he changes the rear end lubricant on his '69 390 hp 4 spd.
    • 15706
    Re: '69 rear end lubricant
    It's in the owner's manual and service manuals. Does he have one. What does it say?
    • Gary R.
      • April 1, 1989
      • 1799
      All you need is non synthetic, 90 or 85-140wt, gear oil and 1-2 4 oz bottles of posi additive.
      • Ralph S.
        • February 1, 1985
        • 935
        • Con X.
          Infrequent User
          • April 1, 1992
          • 23
          I used these.
          • Gary R.
            • April 1, 1989
            • 1799
            As have I and about 1000 others I rebuilt diff's for. I change it out every 8-10k miles. Now you have to get that 64 on the road!
            • Owen L.
              • September 30, 1991
              • 882
              Buy the AC Delco differential oil #10-4016 (2 bottles) and Positraction additive #10-4003 (2 bottles) -- both available at your local GM dealer, local auto parts, Amazon, Summit, etc. Squirt 1/2 bottle of fluid into the diff, add both additives to the bottle, shake it a bit and empty the bottle into the diff. Add the second bottle until the fluid seeps out the fill threads. Be careful to use a long nozzle straw so that if it comes off the bottle it's not lost inside the diff housing...
              • Gene T.
                • May 31, 1997
                • 78
                Thanks everyone for the info. I have passed along all of these recommendations
                  • 15706
                  My 1963 Corvette Shop Manual, page 0-7, states the recommended lubricant for the T-10 and axle is"
                  "Lubricate with SAE 80 or SAE 80-90 Multi-purpose Gear Lubricant meeting the requirements of U. S. Ordnance Spec, Mil-L-2105B."
                  HELP! Does anyone know where I can find some?
