Opinions Sought. Added Power Steering On A 1963 340 HP Car - NCRS Discussion Boards
  • Chuck G.
    • May 31, 1982
    • 2039
    A friend has a 63 convertible, 340 HP car. He added Chevrolet/GM/Corvette power steering to the car 35 or more years ago. He's now thinking of having the car judged. He asked my opinion about deductions... I have an opinion, and came up with a number.
    I'd like to get others' opinions.
    The oil pan was changed, the crank/WP pulley were changed, the alternator pulley was changed, the PS pump, brackets and extra belt were added, etc. Of course, we have the extra PS items in/on the steering linkage..
    Thoughts?
  • Chuck G.
    • May 31, 1982
    • 2039
    Re: Opinions Sought. Added Power Steering On A 1963 340 HP Car
    Since nobody has jumped on my question so far, I came up with between 40 and 60 points to be deducted, using CDCIF. I have not seen the car for decades. I have seen a few photos.
    On several items that come to mind, side exhausts and Vintage Air, there are rather standard deductions for those items.
    • Keith B.
      • September 15, 2014
      • 1604
      Chuck I am going to assume the engine suffix is original and coded for a 340hp and he will be presenting as such?
      • Chuck G.
        • May 31, 1982
        • 2039
        Yes, original real deal 340 HP car, RE suffix.
        • Larry E.
          • 1698
          Why not try concours stock judging? It may come down to a Blue Ribbon in Concours vs a Red Ribbon In Flight judging. I would go the Concours
          route. JMHO Larry
          Larry
          LT1 in a 1LE -- One of 134
          • Harry S.
            • July 31, 2002
            • 5344
            I've been thinking about this:
            • I do not recall seeing a standard deduction on this.
            • I assumed the Chassis Team spoke with the Mechanical Team as to not double-dip on the pulleys.
            • I assumed all the P/S parts are Corvette parts.
            • I assumed all the parts are in excellent condition.
            Saying that:
            • The oil pan is worth 8 points, 20% hit on Configuration, - 1.6 points, round to 2 points.
            • All the P/S parts are worth 8 points, a 40% hit on Configuration and Installation, - 3.2 points, round to 3 points.
            Looks like a 5 point hit, What did I miss?
            • Gary B.
              • February 1, 1997
              • 7070
              • Harry S.
                • July 31, 2002
                • 5344
                Gary, the one place I did not look, Yep 16 points. Then the 2 for the oil pan. Everything else as I recall is the same. So 18 points.
                And No, P/S could not be ordered in 63 on a 340 or 360 hp car.
                • Keith B.
                  • 1604
                  Originally posted by Gary Beaupre (28818)
                  Harry,
                  If detected, added power steering is explicitly mentioned in the Judging Reference Manual in Section 4, Standard Deduction…, sub-section 9. Added or Deleted Options. “The detectable addition…of any regular production vehicle option subsequent to factory assembly is … subject to a full deduction on originality and condition. Examples: … power steering…” So, at a minimum, I assume this means the 8 pts for originality and 8 for condition on the Chassis line item “Power Steering: pump, pulleys…” So, 16 points there. And what about any associated items that might have changed or altered, like the steering column, rag joint, steering box, steering damper. It could add up to a fair amount. Unless everything is done so as to be undetectably different from an original power steering car.
                  Was it even possible to order power steering on a ‘63 340 HP car? That question shows my ignorance about ‘63s in general.
                  Gary
                  no it was not available due to the larger five quart oil pan and interference with linkage
                  • Gary J.
                    • April 1, 1980
                    • 1246
                    Even if the point deduction were as high as 45, in the grand scheme of thing that is not but a 1% off of the raw score, leaving you with a 99% if everything else is perfect.
