Restoring opaque washer fluid tank - NCRS Discussion Boards
  • Robert G.
    • April 13, 2017
    • 72
    Does bead blasting work to remove the discoloration?
    Any suggestions on what does?
    Thank you
    • 43219
    Re: Restoring opaquewasher fluid tank
    Thank you
    Robert-------
    I don't think there is anything that will restore the washer reservoir to its original appearance. The discoloration is more than "skin deep". Even if you could remove the discoloration you'd never restore the reservoir to its original surface texture and appearance.
    • Mark E.
      • April 1, 1993
      • 4536
      If it's discolored from washer fluid on the inside, try white vinegar. I've used that to good effect on plastic drinking cups with build up. Stronger options are CLR and bleach.
      To Joe's point, this probably won't restore it to its original look but may remove much of the build up and staining.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Robert G.
        • April 13, 2017
        • 72
        Thank you Joe
        • Robert G.
          • April 13, 2017
          • 72
          Thank you Mark
          • Bill S.
            • April 30, 2002
            • 154
            Here is a 1 youtube video there are many others where old yellowed plastic tanks have been restored
            Bill Strobel
            Owner Independent Towing
            Fayetteville, NC
            1979 Corvette White/Red L-82 4 spd
            Only 4,200 miles
            Do It Right or Don't Do It At All
              • 43219
              https://www.youtube.com/watch?v=JqCN...B6AvrE&index=3
              Bill------
              I'm a little surprised that the reservoirs can be so easily restored. However, for this to work the discoloration would have to be simply residue which accumulates on the exterior and interior of the part and not actual deterioration of the polyethylene or polypropylene plastic, itself. That sort of deterioration would be more than "skin deep" and, thus, not amenable to this type of restoration which is actually just a thorough cleaning. I suppose, though, that plastic components like radiator overflow/supply tanks and washer reservoirs are essentially shielded from the sun so are not subject to its deteriorating effects.
              • Gary B.
                • February 1, 1997
                • 7018
                Bill------
                I agree with Joe. I’m skeptical of that YouTube video. If you read thru the video comments, you’ll see that others are skeptical of the truthfulness of the video. Some people say the old tank was switched for a new one. I would like to see the process repeated by someone we know and trust, say using an old Corvette reservoir. For skeptical views, read the replies after this comment on the video:
                @patmx5
                2 years ago
                Looks like the cleaning process also turned the brass nipple inserts silver and raised the molded tank lettering, too. Impressive! /s
                  • 6941
                  Robert, I can tell you I put my 63 washer jug in the dishwasher years ago and it did a pretty good job by its self, I think some patina Is ok as judges like that. Is you show your you use to be able to at one point get a mid year NOS one at a reasonable price. Very little difference.I don’t like dealing with the acid as you have to dispose of it correctly and just dumping it will harm the environment.
                  • Michael B.
                    • June 18, 2007
                    • 400
                    I tried this last year on a tank out of my 78 Monza. It doesn't work and the YouTube video is fake. I actually left it submerged for over a month. I tried it using ultraviolet light too. I also tried a solution of hair bleach and water, wrapped in plastic wrap and left in bright sunlight for days. Nothing worked to being back the whiteness.
                    • James G.
                      • August 22, 2018
                      • 800
                      Try 30 or 40 volume PEROXIDE and a UV lamp. I have used the technique on white and light colored interior parts after seeing someone on youtube restoring light grey and white plastic toys from the 60's and 70's. Doesn't take much more than overnight, you will not believe the difference in removing the yellowing.
                      James A Groome
                      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                      • Ronald L.
                        • October 18, 2009
                        • 3248
                        One catch - modern tanks are made of a different material, its going to be harder to remove yellowing from decomposition.
                        • Thomas N.
                          • July 31, 2002
                          • 397
                          I've used hydrogen peroxide and water mix, and put rice inside of the tank to clean out sludge and some staining. The rice provides a little scrubbing action and agitation. Worked good for me to get rid of sludge inside and brightened it some. Not sure if it will work for all based on the level of staining or a change in the material itself, but might be worth a try.
                          NCRS New England Chapter Chairman 2022, 2024
                          N E Regional Chairman 2024
                          1967 Corvette Convertible Under Restoration
                          1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
                          • Patrick N.
                            • March 10, 2008
                            • 954
                            "Try 30 or 40 volume PEROXIDE and a UV lamp".
                            I have done this technique on many old toys and even old instruction manuals - works very well! In the summer, I skip the UV lamp and just leave a tub with the mixture soak in the sun for an hour or so. As mentioned, I also have put some in a spray bottle and soaked old instructions. They whiten right up as well.
                            • Ron G.
                              • December 1, 1984
                              • 865
                              Robert,
                              I have to agree with Joe. I have tried several different methods, and the only thing that helps marginally is dispersing the entire neck and container in straight bleach for several days. Even doing that you will not be able to bring back the original color.
                              - Ron
                              "SOLID LIFTERS MATTER"
