Question for the painters help with "foggy" paint - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
    Guys,
    I've been painting chassis/suspension parts for years with no problems. Of course the room for error on those parts is large but I've had good results. I recently decided to try to start doing some of the painting on the body when the situation calls for it. I decided to practice on the rear bumper of my 2010 Mercedes that had gotten rear ended a number of years ago. I removed the bumper and repaired the damage. I've tried twice now to paint it and the finish always comes out poor. I'm using Nason base/clear system. The first time, I used the standard medium reducer. Thinking it was drying too fast, the second time I used their slow reducer but both times there is a lot of fog in the paint. I'm in TX and I'm doing this around my day job etc and I can only do it when I can do it which means the middle of the day. With the lights in my little "paint booth" (plastic tarps) and the 105 degrees outside it is easily 110-115 degrees in the booth when I spray. I'm guessing I'm still drying too fast? I've asked and this Nason system doesn't have a retarder for it. What are my options at this point? Wait until the Fall? What about another system that has a retarder? See the pics below for what it looks like. I was very meticulous about gun set up and it seems to go on OK but just dries looking like this. Thanks for your help.
    Mike
    • 11698
    Re: Question for the painters help with "foggy" paint
    Are you attempting to paint and clear only one portion of the bumper?
    • Mark E.
      • April 1, 1993
      • 4613
      Blushing paint ("fog" as you say) is caused by moisture in either the compressed air source or the atmosphere. Only the most experienced painters can make it work during a hot, humid day in Texas.
      Wait for a low humidity, moderate temperature day and make sure the compressed air is dry using a good water trap. Keep the petcock on the bottom of the tank cracked open too.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Michael L.
        • December 15, 2006
        • 1424
        Yeah I figured it was the heat/humidity that was killing me. I have two standard moisture drains on the line and I have the QC3 air filter and dryer too but it may not be enough. I think I'll just have to wait until October rolls around.
        No, Patrick, I'm base coating the whole bumper. That is just the base coat you see on the bumper there.
        • James G.
          • August 22, 2018
          • 819
          Try running a bulb filter right before the gun, I have had warm air cause condensate inside the hose which laid on a cooler floor.
          James A Groome
          1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
          1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
          My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
          Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
