'54 Steering Wheel - NCRS Discussion Boards
'54 Steering Wheel
  • Brian W.
    • September 30, 1990
    • 216
    '54 Steering Wheel
    I'm removing the steering wheel and using the ST12 service guide and it states to pry out the horn button. I have a ring but it should be the same and it will not pry out. Is there any other tricks I can try? The ring is lose and the horn works but will not come off. Help needed. Thanks.
    Brian
  • Mike E.
    • February 28, 1975
    • 5141
    Re: '54 Steering Wheel
    Pry out the center plastic ornament carefully, and you will see retainers behind it. 56-62 you pop off the horn button.
    • Brian W.
      • 216
      Thanks Mike that did it
