C4 rear hatch releases - NCRS Discussion Boards
  • Dana A.
    Infrequent User
    • August 12, 2017
    • 6
    Hi all,
    I have a '92 ZR1 with 2500 miles, Im preparing for NCRS performance verification as well as Bloomington Benchmark.
    The NCRS manual says for 92-96, with the key on or off the parking brake has to be set (manual transmission) to operate the hatch releases on the doors and in the center console.
    Key on or off and brake set or not set, the door switches will operate the rear hatch. If the key is on the brake has to be set for the console switch to work. Is this right?
    If you have knowledge on this or a fix it would be greatly appreciated.
    I wouldn't even know where to start if this isn't right.
    Thanks for your time
    Dana
  • Chuck B.
    • August 31, 1987
    • 122
    • John M.
      • May 31, 1990
      • 198
      Re: C4 rear hatch releases
      I agree with Dave and Chuck. Your switches sound as though they are functioning correctly. The switches function the same on a non ZR1. My 92 6 speed LT1 function as described.
