The right rear brake lights on my 65 are only working intermittently.
I am sure the problem is in the indicator assembly on the steering column as the left and right indicators work OK.
When I have the hub of I cannot get the fault to appear!
I have sprayed contact cleaner into the switch assembly and the fault still appears when I am driving according to those behind me.
I would like to have a closer look at the contacts but they are under the cancelling pawl.
Once the bolt is removed from the pawl can the pawl be removed or is it fastened from the rear?
Gary
Gary
 1965 Intermittent RH brake lights
