STV Rebuild/ Molykote Type Z - NCRS Discussion Boards
  • Gino R.
    Infrequent User
    • July 31, 1994
    • 17
    Hi All,
    Finally back at it. Starting to rebuild my suction throttle valve and ran into a couple of questions/problems that I was hoping the you guys could help me with?
    First of all I took apart the STV and I am a little concerned with the condition of the bore. It feels smooth when I put my finger in it....(passed the finger test), but there are definitely some dark areas and and some small imperfections. I have attached a couple of pictures. Let me know what you think.
    Secondly, In the Service Manual on the rebuild they reference a powdered Molykote Type Z which seems to be quite expensive and hard to get, especially for just a small amount that I would need. Is there a substitute for that product? Or should I just bite the bullet?
    Lastly should I take apart the Schrader valves apart for cleaning? I am concerned that there is dirt inside of them, but I don't want to damage them or cause them to leak when I start messing with them.
    Thanks for the help
    Gino 66 Coupe
  • Harry S.
    • July 31, 2002
    • 5344
    Re: STV Rebuild/ Molykote Type Z
    Gino, when I rebuilt the STV for my 63 10 years ago this is what I did.
    • cleaned all parts inside and out with alcohol
    • Used 12,000 grit water based sand paper so ensure all was smooth
    • cleaned again with alcohol and blew it out with compressed air.
    • Installed an NOS diaphragm (rubber and Metal)
    • Re-assembled the unit
    For me, it's been working fine sine the rebuild.
    Good luck
    Harry
    • Gino R.
      Infrequent User
      • July 31, 1994
      • 17
      Thanks Harry for the advice,
      I will be hoping for the same results. I appreciate the Help!!
