Favor on fuel pump date code interpretation - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    So I have been offered a fuel pump with the ID below but I am travelling all week and no access to my JG. Anyone know what the date code below translates to?
    251W40658
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Bill B.
    • August 1, 2016
    • 306
    Re: Favor on fuel pump date code interpretation
    Keith,
    According to my 5th ed '70-'72 JG, all 1970 pumps had a two letter code for the month and year, while '71 & '72 have a Julian date code but the year code is not shown. Don't know about the '68 or '69 pumps.
    "251" sounds like a Julian date for September.
    Bill Bertelli
    Northeast and Carolinas Chapters Member
    '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
      • 11692
      Note that the "W" makes it a much later service replacement.
      I would expect H for 1968, I for 1969, J for 1970
      • Tom R.
        • June 30, 1993
        • 4102
        Keith...you're well into the 80's with that date code. Here is a page from a TIMJG...well it wouldn't let upload a single freakin page but here it is.
        13. FUEL PUMP
        The upper body of fuel pumps are die-cast aluminum with a stamped-steel gold-irradiate lower extension crimped to the upper body. The upper body has a smooth die-cast look not a media-blasted finish. Near the fulcrum for the lever, the AC logo is cast into the narrow supporting portion. (See Fig. M 13.0)
        The fuel-pump flange has a model stamp on the rear underside of its base (the flange that bolts to the engine). All fuel pumps use a Julian date code (three digits), followed by the last five digits of the part number. A letter year is used for the calendar year of pump assembly. A pump with the code 117S41240 is April 27, 1977 date code. (Fig. M 13.1 A fuel pump installed on a 1977-built in 1976, is expected to show a 1976-year code. Table 16 lists part numbers by model year.
        The pump attaches to the engine by two zinc-plated indented hex-head bolts with integral split-ring lock washers. One bolt is 7/16" hex and another is 9/16."
        A natural steel unpainted plate is between the fuel pump and engine block. It connects to the block by two zinc-plated indented hex-head screws with integral external star washers. Original gaskets under the fuel pump and plate are tan to dark brown. (See Fig. M 13.3) The date codes of reproduction and service-replacement pumps are stamped in a different location and the die-cast finish is not typical factory production.
        I see uploading the table distorted the columns.
        Table 14– Fuel Pump Part Numbers & Date Codes
        Year Engine Date Code Part Number
        Stamped on Flange Published Sources
        1974
        1975
        1976
        L48/L82 N
        P
        R
        6640769 6470308
        1977 S 6442140 6471216
        1978 T
        1979 U
        1980-81
        Tom Russo
        78 SA NCRS 5 Star Bowtie
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Keith M.
          • January 17, 2021
          • 695
          Thanks all!!
          • Dan A.
            • February 1, 2004
            • 212
            Is it possible that a fuel pump built in 1971 could have the Julian date and year stamped on it? The fuel pump on my early build 72 LT-1 is stamped 162140956 and that date would about right for the pump.
            Thanks.
              • 11692
              I would bet it's 162L if you have a very late 1971
              • Tom R.
                • June 30, 1993
                • 4102
                251W40658
                My curiosity got the best of me so I Googled the 40658 and up popped this offer on eBay for pump, dated for a 68-69 Corvette. Date code configuration must be different for those two years...it may be a 327 vs. 350 thing.
                This is for One New NOS  GM ACDelco #40658  GM# 6417337  Corvette Fuel Pump   Fits model years:   1968 1969   In a 1991 dated AC-Delco box
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                  • 11692
                  https://store.tracyvette.com/item/20839/
                  The pump appears to be 172H40658
                  That would be the 172nd day of 1968, which fits. I'm not sure what you're seeing that's different?
                  June 20, 1968 assUming it's a 172.
                  • Dan A.
                    • February 1, 2004
                    • 212
                    Patrick,
                    I believe you’re correct. Would this date work for 72 LT-1 built 8/26/71?
                      • 11692
                      Originally posted by Dan Agnew (41438)
                      Patrick,
                      Perfectly.
