C1 Clutch Problem - NCRS Discussion Boards
C1 Clutch Problem
  • Salvador B.
    • May 11, 2008
    • 50
    C1 Clutch Problem
    The clutch pedal in our 1957 gets stuck on the floor. What could cause this?
  • E B.
    • March 1, 1978
    • 127
    Re: C1 Clutch Problem
    Static or at high rpm ?
    • Christopher R.
      • March 31, 1975
      • 1599
      Clutch adjustment. See the ST-12 for instructions on how to adjust.
      • Mike E.
        • February 28, 1975
        • 5153
        Possibly the wrong pressure plate. Should be borg and beck 3-finger one.
        • Dennis C.
          • June 30, 2002
          • 888
          As mentioned above, go through the adjustments for the clutch in the ST-12. There is an adjustment in there for the overcenter condition you are experiencing.
          I suggest following the instructions for check out and adjustments as written in the ST-12 carefully.
          • Salvador B.
            • May 11, 2008
            • 50
            Sorry for our ignorance, but what is the ST-12?
            • Jimmy G.
              • November 1, 1979
              • 977
              Happened on my 60 also Wrong clutch assembly I had an extended fingers pressure plate and with the "OVER CENTER PIVOT" of the linkage it stuck several times. Once at 6500 RPM OUCH Changed to a regular assembly --- NO MORE ISSUES!!!
              • Mike E.
                • February 28, 1975
                • 5153
                Sorry. ST-12 is the GM service manual for 53-62 Corvettes. Available in many places. Has the sketch of a blue sailboat on the front.
                • Steven B.
                  • June 30, 1982
                  • 4018
                  ST-12 is the service technical guide available at the top line of this page under STORE, C1 Books on page 3 or4 for $30. A wealth of knowledge written by GM. Good Luck!
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11369
                    Salvador, We need some history....
                    Is this a new clutch, or is it a older clutch that has been working but now has this problem?
                    If new, exactly what was installed?
                    If new, is it a bent finger or flat finger modern disk or Borg & Beck 3 finger?
                    What height throw out(release) bearing was installed?
                    Is the clutch fork and rods/linkage/pivots/overcenter(Gorilla)spring all stock or modified?
                    Is the fork a proper C1 58-62 fork? If a 64-up fork is installed, the geometry difference would cause improper operation as well.
                    As asked, does the pedal stick to the floor with engine off, or only when at some high RPM?
                    This "pedal stuck to floor" is a common issue with replacement (correct)bent finger clutches on C1s. The ST-12 based clutch adjustment is critical, but sometimes requires some mods to the cross shaft/z-bar pivot hardware to correct when using these.
                    See this link for a online view of the ST-12 clutch info, see Sec 6r.
                    I recommend a hardcopy too from our NCRS store.
                    Rich
