Radiator neck/ cap leaking - NCRS Discussion Boards
  • Anthony C.
    • March 21, 2022
    • 207
    • 43219
    Re: Radiator neck/ cap leaking
    • Anthony C.
      • March 21, 2022
      • 207
      Hi joe . It is leaking underneath the cap . Neck joint is fine .. it is possible I did shave of some brass when turning . If so any tips to correct it. Thanks
        • 43219
        Anthony-------
        Only three things I can think of:
        1- Add a gasket to the cap
        2- Try another NEW SERVICE cap
        3- If the above does not solve it, have the filler neck replaced by a radiator shop
        • Mark E.
          • April 1, 1993
          • 4536
          A tip for next time- spray the cap gaskets and mating surface with silicone to help it twist together without galling.
          And as Joe mentioned, avoid excessive force on the neck. If the neck has a bend, I place a hand under it while twisting and pushing the cap.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Anthony C.
            • March 21, 2022
            • 207
            Appreciate it Joe thank u
            • Anthony C.
              • March 21, 2022
              • 207
              Thank you mark appreciate it
