1111490 Distributor Dimensions - NCRS Discussion Boards
  • Peter S.
    • March 28, 2012
    • 327
    Hey all,
    I'm looking for the height from the flange to the top of the distributor cap on the 1111491 TI distributor for 1969 350. Does anyone have this information, or can pull this dimension for me?
    EDIT: Correct part # is 1111491
    • 15667
    Re: 1111490 Distributor Dimensions
    I'm not sure what you mean by "flange", but all single point/TI distributors, both small and big block, have the same exterior dimensions with the exception of those used on some, if not all, FI engines.'
    • Peter S.
      • March 28, 2012
      • 327
      Hi Duke,
      By flange, I'm referring to the donut just below the tag where the distributor mounts to the intake manifold.
        • 43219
        Originally posted by Peter Stout (54749)
        Hi Duke,
        [ATTACH=CONFIG]118070[/ATTACH]
        Peter-------
        I don't know why this dimension is significant to you but the dimension from the bottom of the distributor mounting flange (arrow in your photo) to the top of the distributor cap center tower of an original Delco cap is 6.77", plus or minus 0.06"
