1970 Rear Window Stowage Tray Rattles - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4614
    The rear window stowage tray rattles while driving this 1970 coupe. I believe the front corners hit the underside of the deck when driving over a bump. I can push the front corners up by hand an inch or so before they hit the deck.
    Ideas for fixing this? From the photo you can see the press board is warped, with the corners sagging down. I'm open to how to restore its shape, or just preventing it from rattling in the shape it's in. Foam cushions?
    The good news is this in one of the last squeaks and rattles to chase down on this car.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • 6960
    Re: 1970 Rear Window Stowage Tray Rattles
    Mark my 72 has rubber bumpers at corners. Not sure about 70.
    • Bob I.
      • November 9, 2006
      • 265
      Hi Mark,
      I used the bumpers from Dr Rebuild.
      Bob
      • Chris H.
        • April 1, 2000
        • 837
        I just used some electrical tape to cover the contact points that were generating the noise.
        • Paul Y.
          • September 30, 1982
          • 570
          Originally posted by Bob Imhoff (46494)
          Hi Mark,
          Bob
          [ATTACH=CONFIG]118032[/ATTACH]
          Those are the ones I used also. Paul
          It's a good life!
          • Gary T.
            Infrequent User
            • April 30, 1994
            • 13
            Mark,
            I have an early '70 (00504) that have 3 rubber bumpers in the tray. The middle bumper is slighlty larger than then the two end bumpers. Also, the have different p/n's. Go to corvette central, p/n 483056 to see what the bumpers look like. They do not look like Dr Rebuild's at all, good luck.
            • Mark E.
              • April 1, 1993
              • 4614
              Bob and Paul- I looked at the underside of my car's rear deck, and there are three patches about 1" square that look like the remnants of adhesive... probably where these cushions once existed.
              Gary- I looked and discovered my stowage tray has three small unused holes, one on each forward corner and one centered on the front side, which look to be about the right size for the CC tray bumpers. Below is a screenshot from their product page that shows two bumpers, not three. I called them and they said they do not sell the center cushion. Since you said it was different, can you post a photo?
              Edward- Does your '72 have cushions like Doc Rebuild or CC or both? How many holes does your tray have?
              This suggests these cars are equipped with three under deck cushions AND three stowage tray bumpers. I wonder if this configuration varies between press board and plastic trays. If anyone can confirm, please post.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Paul Y.
                • 570
                I also wrap my rear window in a cotton bath towel when removed and stored and leave it in the storage tray when not in use and it seem to mute and insulate a lot of the rattles. Paul
                It's a good life!
                • Mark E.
                  • April 1, 1993
                  • 4614
                  Thanks Paul. Since my tray is warped, I haven't used it to stow the window. My issue is the tray rattles when empty.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Bob I.
                    • November 9, 2006
                    • 265
                    I found three locations, that had remnants of adhesive possibly from the previous bumpers on my 1970. The window tray, also has the three holes.IMG_1100.jpgIMG_1101.jpg
                    • Paul Y.
                      • 570
                      I put a double or triple layer of towel all along the front side except where it latched to prevent contact. Mine also was warped some and I forced it a bit in the areas that were low. My hinge screws came loose on me also and I lock tightened them up . Paul
                      It's a good life!
                      • Mark E.
                        • April 1, 1993
                        • 4614
                        Good idea. Placing a towel on the empty tray may help.
                        Has anyone successfully straightened a press board tray? Steam? Heat gun? Weights? I want to avoid causing damage while trying to straighten it.
                        Mark Edmondson
                        Dallas, Texas
                        Texas Chapter
                          • 6960
                          [ATTACH=CONFIG]118065[/ATTACH]
                          Mark those look like the cushions on my 72, I think I only have two on mine but will take peak tomorrow for you. my tray is fiberglass??? Not fiber board.
                          • Mark E.
                            • April 1, 1993
                            • 4614
                            Thanks Edward; let me know what you find.
                            To the rear window tray experts-
                            Let us know if there are two or three cushions on the tray and if the middle cushion is different. Also, are the press board and plastic trays different?
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                              • 6960
