c2 67 ground wire below the glove box door - NCRS Discussion Boards
  • John A.
    Infrequent User
    • April 20, 2008
    • 18
    In the process of removing aftermarket stereo and alarm system from previous owners. Unfortunately, I a few chopped wires and I trying to figure out where the wire leads to. Specifically is the ground wire located under the grove box door. What is the ground for? I attached a sample to show the wire I am questioning. Any help is appreciated.
  • John A.
    Infrequent User
    • April 20, 2008
    • 18
    Re: c2 67 ground wire below the glove box door
    To add to my post, the clip is there but no wire on my car.
    • Jeffrey S.
      • April 1, 2004
      • 133
      I don't believe that is part of the original harness . I didn't have one on my 67 in that position / probably an add on from the previous owner. Hope this helps Jeff
      • Leif A.
        • August 31, 1997
        • 3655
        That wire was not there from the factory nor was a clip. Most likely, something from the aftermarket stereo (ground) or the aftermarket alarm.
        Leif
        • Keith B.
          • September 15, 2014
          • 1604
          and furthermore take some lacquer thinner to the vin and trim tag and remove the paint. and As Leif said that is not factory
