C2 Door Gaps Again - NCRS Discussion Boards
C2 Door Gaps Again
  • Larry E.
    • 1703
    C2 Door Gaps Again
    Decided to start new thread on this subject. I also have a 66 Convertible with a similar problem.
    Have a gap problem on the Drivers Side Door. Not a width problem with the gap but a depth problem.
    My Door skin is not "flush" with the back half of car. Not real bad and can live with this if needed.
    The depth problem is very constant from top to bottom. Question>Can the latch and catch for the door
    be adjusted to "pull" the door in a little farther? If so How?? Thanks In Advance>Larry
    P.S. In searching this subject on this board it seems that the 1966 especially the convertible are more
    prone for this situation. JMHO
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1703
    Re: C2 Door Gaps Again
    Ok; got it solved. Should have done a more better search. Loosened the three Phillips Head screws on the
    "Latch"(Not sure it is called that) that is attached to the post of the car. Pushed the latch to the center of the car in small stages
    and the "flush" gap disappeared. By doing this the gap on the door near the front fender grew a little which
    was good as it was on the tight side to begin with. Onto the next job. Thanks> Larry
    Larry
