How Many Different Interior Side Panels(Below Radio) where there for C2's? (1966) - NCRS Discussion Boards
  • Larry E.
    • 1692
    We know for sure there where 2 different Driver Side panels varified by the Judging Manual For
    1966's. Do not know if this applies for the 1965 and 1967 models. If radio was not ordered there
    was no provisions for the radio antenna switch. But here is the kicker:
    I have seen some Corvettes with the C48 (Heater Delete) option that the side panel did not extend
    as far back as the above two do. I have seen these cars on the Bloomington Gold and NCRS
    judging fields. So where there (3) different types of side panels? Has anybody else seen this??
    Please Comment and thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Keith B.
    • September 15, 2014
    • 1588
    Re: How Many Different Interior Side Panels(Below Radio) where there for C2's? (1966)
    if its not called out in the AIM then there would have been only two. and without looking at the U69 section to verify you sure the line worker did not make the holes for the antenna switch from the "base" side panel?
    • Larry E.
      • 1692
      Keith: We DO know that the AIM/Judging Manual can be wrong in certain cases. AFA the C48
      option goes for the 1966 not much detail is given for this super rare option. Larry
      Larry
      • Keith B.
        • 1588
        Since I never worked on or judged a C48 car I really can't comment on the AIM being wrong. Does the parts book reflect your findings?
        • Larry E.
          • 1692
          Keith: Thanks for your comments. I doubt if it is even mentioned in the Parts Book due to the rarity. Very similar to the
          colored plugs that where put in below the clock. No one ever figured out who painted these IIRC. Larry
          Larry
          • Larry E.
            • 1692
            Here is a picture I took off the internet. Perhaps it was a optical illusion on my
            part (compare the top two)as suggested by another member of this board. I'll see if I can find more
            pictures. Larry
            Larry
            • Larry E.
              • 1692
              FWIW>Hope I am not beating this subject like a dead horse. Got some measurements for a 66 Driver Side Panel. Length starting
              from around the #224 flasher(a little bit towards the firewall) to the end of panel(towards the shifter) is
              around 9:1/2 inches. Percent of opening covered from firewall to where panel ends(by shifter) is around
              55 to 60%, So I'm seeing around 45% or so not covered. CAN SOMEONE MEASURE A 64 TO 66 WITH
              A RADIO and HEATER AND GET ME A COMPARISON?? I have my radio 66 Coupe already stored in a Omni bag so
              can not get to it to measure. Thanks again>Larry
              Larry
              • Larry E.
                • 1692
                ANYBODY??? THANKS>Larry
                Larry
