Re: Trailing Arm Question
I agree. I think the "missing/lost shim problem" is primarily due to improper installation. Few seem to know that the shims should be a light interference fit. In other words, the last shim, a thick one, should require light tapping with a small hammer to install and seat. Then properly torque the trailing arm nut to spec with the suspension at normal ride height, and the shims will likely stay there forever or until the toe in needs to be readjusted.
