Request Interior Photo(s) for 2009 Corvette C6 Coupe - NCRS Discussion Boards
  • Rob V.
    • July 31, 2002
    • 261
    Greetings--
    I respectfully, (and hopefully), request that a member can provide an interior photo, (or photos), of the left rear (driver's side) interior carpeted corner of a 2009 Corvette C6 Coupe, where a emergency release cable for the rear window/hatch is located.
    Background/reason: On Friday, 14 July 2023, my daughter and her cat, (in a pet carrier), became locked, (trapped), in her 2009 Corvette C6 Coupe when a dual failure of her vehicle remote and the vehicle battery occurred. Before her mother and I could respond and assist her, she had already attempted to "pull" two (2) wires located in the carpeted left hand rear interior corner of her car, in an attempt to extricate herself and the cat. Her mother and I were subsequently able to open the coupe rear window
    /hatch with the aid of the releasable key in the spare remote (which also had a dead battery); have our daughter hand us the vehicle owner's manual; and re-read the sections relating to emergency door opening, and emergency rear window/hatch release. The owner's manual implied that there should be a release handle for the rear window/hatch which I could not see or find. What I did observe were two separate, thin, solid wires, that were not connected; and one having an end that had attached at the free end, something resembling electrical contacts. I have no idea what the two wires are; nor what the emergency rear window/hatch handle looks like.
    I have not driven this car for over six years; and when I gave it to my daughter at that time, I thought we had covered how to open both the doors, and the
    rear window/hatch when there was an electrical failure. However, it was patently obvious that neither of us remembered how.
    Thank you in advance, for any and all assistance with regard to this matter!!
    Rob
    SPEAK YOUR MIND, but ride a fast horse. -- Anonymous
  • Don H.
    Moderator
    • June 16, 2009
    • 2262
    Re: Request Interior Photo(s) for 2009 Corvette C6 Coupe
    Here you go, on an 08 coupe.. Has to be the same on an 09. Two pull handles,,each with a little slice in the rug to stow in..
    Both the plastic pulls on the two wires must have gotten lost on your daughters car.. Maybe the cat ate them?
    I think the rear one is gas door release.. My owners manual is not handy check it. ps. I'll bet those two pull tabs are down behind that rug..
    • Brian M.
      • November 1, 1994
      • 124
      I recall there are small levers on each side on the floor next to the seat.
      Take a look.
      Brian McIntyre
      • Don H.
        Moderator
        • June 16, 2009
        • 2262
        You're correct Brian.. There are manual release levers next to the seats.. and the pull tab in the back is another manual door release, NOT a hatch release..
        now you got me exploring this feature.. It looks like the pull tabs might likely slide forward on the wires, rather than fall off the wires.. Meaning, if you chased the wires some, into the cabin area under the rug, the tabs are probably there, still on the wires. Don't blame the cat.
        nothing better to do today.. so I pulled out my owner's quick guide.. If locked out of the car, use the hidden key in your fob to open the hatch above your rear license plate.. Then pull the door release tab to open driver's door... If locked in the car, pull manual door release lever next to either seat up. Or, if you have long arms, reach back to the pull tab in photos here.
        • Brian M.
          • November 1, 1994
          • 124
          Brian McIntyre
          • Don H.
            Moderator
            • June 16, 2009
            • 2262
            I read it when I bought car a year ago.. Since then forgot almost everything in it..
            • Michael J.
              • January 27, 2009
              • 7122
              Yes, as Corvettes have become more electrical gadgets than mechanical devices, there is more danger that lurks in the electronics.
              • Brian M.
                • November 1, 1994
                • 124
                Right you are Michael.
                On the C6, there is no clunk sound when you lock the doors. I assume the lock removes power from the open the door switches. Lots of opportunity to go wrong.
                On the C7, there is a clunk when you lock the door. There must be a locking mechanism. Interesting GM went back to a mechanical locking mechanism. there must have been a good reason.
                Brian McIntyre
                • Michael J.
                  • January 27, 2009
                  • 7122
                  Agreed, they saw the mistake and to their credit they fixed it. I am always terrified when my C8 says it wants to update the software OTA, and it will take up to an hour. I always remember the PCs and laptops I have had which didn't recover from this procedure, and I have heard it doesn't always work out correctly, they call it "bricked".
                  • Rob V.
                    • July 31, 2002
                    • 261
                    Don--
                    Thank you so very much for taking the time and effort, (with expedited response to my query), to photograph the requested interior area of your C6; and explain the function of the subject cables!! We will use what you provided to reacquaint my daughter, my wife, and me with their function!! When I purchased the car approximately 8 years ago, one of my friends who had a 2007 Corvette Coupe warned me of the danger of power loss; and explained that some old guy had "expired" in his car when he could neither get out or summon help. Whether urban legend or true event, it illustrated the dangers of power loss in these newer cars if one is not totally familiar with their specific operations and quirks. Yet another reason I like the old C1s/C2s!!
                    Thank you again for your very kind and timely response!!
                    P.S. I am not convinced the cat did not play a role in causing the occurrence.
                    Rob
                    • Don H.
                      Moderator
                      • June 16, 2009
                      • 2262
                      you're welcome Rob. That old guy was probably younger than me,,, and I thought I read that his dog expired along with him.. All he had to do was pull up on the release lever next to the seat. I agree with you, give me my 64 any day..
                      • Rob V.
                        • July 31, 2002
                        • 261
                        Hey Don--
                        Two (2) last comments:
                        1). My 1964 C2 roadster is sitting next to my daughter's 2009 C6 Coupe in the garage.
                        2 ). Much to her chagrin, my wife's 2018 Mustang GT is sitting on the driveway covered by multiple car covers. Love living on the edge!
                        Thanks again!
                        Rob
