1964 Control Arm & Spring Removal - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
    I'm ready to tackle this job. Have the threaded rod set up with the lower block from Tom Nowak. The steering linkage is all removed already, so these are the steps I plan to follow. Please weigh in if you see any issues.
    1. Remove sway bar and front shocks
    2. put the car on jackstands on the frame.
    3. remove front wheels
    4. Mine is a '64, so no brake caliper to worry about. Remove drum and shoes.
    5. Loosen upper and lower ball joint nuts and the lower control arm cross shaft bushing bolts.
    6. Install Nowak block on threaded rod with nut below to lock in place and rubber mat to protect lower control arm
    7. Grease the rod and pass it through the shock tower and use two washers and a nut on top. Grease between the washers.
    8. Compress spring.
    9. separate lower ball joint from steering knuckle
    10. swing lower control arm out of the way
    11. decompress and remove spring
    12. remove control arms
    Thanks.
  • Leif A.
    • August 31, 1997
    • 3626
    Re: 1964 Control Arm & Spring Removal
    Mark,
    Sounds like a safe and well thought out plan. I see no need to remove the brake drum and shoes, however.
    Leif
    • Gary B.
      • February 1, 1997
      • 7018
      • Gary J.
        • April 1, 1980
        • 1241
