The 63 that I worked on is having problems with the right rear brake becoming warm. It seems to take 8-10 miles of driving for it to occur, as with my last 5 mile test I had no issues, and all 4 rims were the same temperature. It was first noted when taking the car to the alignment shop 2 weeks ago, the longest drive in the car to date at 8-9 miles each way.
The rear wheel bearings were redone by a well known restoration shop. All brake components are new, including wheel cylinder, springs, shoes and emergency brake cables. All 4 drums were turned.
When I took it apart after the alignment shop the right rear shoes had wear (evidence of contact) around most of the pad already, and the left (not problematic) side had wear to about 50% of the surface. The right drum was a bit tighter than the left on removal. I backed off the right rear adjuster quite a bit, and there was no contact between the shoes and the drum. The car was then driven a few miles with no issues and no heat. I did drive it forward and reverse in the driveway to work the adjusters.
Today the caretaker let me know that the right rear is again warm. It brakes straight and does not pull, and did not pull before the last adjustment.
Is there something else I should look at as to the cause? If the shoes are again too tight, is there a way to fix (?) this and prevent recurrence?
Thanks for any tips you may have.
