Correct hardware for mounting 68/69 rocker moldings? - NCRS Discussion Boards
  • Ray S.
    Infrequent User
    • April 23, 2017
    • 18
    Hi,
    Unfortunately, like many things in the aftermarket these days, I suspect the mounting kit I received is not quite right.
    In particular, the screw clips that hold the upper trim to the lower (fiberglass) rocker molding seem to be too tall, whereas they'd be visible after the upper trim is installed. I'm guessing they should be the much shorter style clip, like that used for the exhaust tip bezels on the rear valance. Can anyone confirm this? Thanks, Ray
    P.S. I believe something like a Dorman 961-300 would be correct...
    Last edited by Ray S.; July 5, 2023, 12:32 PM. Reason: added additional information
