C2 - 1966 Roadster - Guidance Sought; Sticky Hood and Soft Top Part - NCRS Discussion Boards
  • Edmund C.
    • April 14, 2015
    • 232
    NCRS Friends: I need some guidance on the following two issues if possible: (1) I put some white lithium grease in the 2 prongs of my hood release and now I can't get the hood to close completely. It will not catch. Should I clean it out or do I need an adjustment? (2) The rubber weather stripping (at the hinge point of the convertible frame) has a rubber piece that was designed to cup & protect the metal hinge from rubbing against the rear deck. Mine was installed incorrectly and is mangled. Who is a good aftermarket supplier for a new one? Any guidance appreciated. Many thanks and a happy 4th of July to all. Best regards, Ned
  • Jeffrey S.
    • April 1, 2004
    • 133
    Re: C2 - 1966 Roadster - Guidance Sought; Sticky Hood and Soft Top Part
    I would say the grease would not keep the latch from working properly/ and corvette rubber is the go to vendor for corvette rubber products/ hope this helps / Jeff
    • Gary B.
      • February 1, 1997
      • 7068
      • Edmund C.
        • April 14, 2015
        • 232
