1963 Parking Brake Handle Assembly Restoration??? - NCRS Discussion Boards
  • Michael B.
    • February 1, 1985
    • 76
    Hello Everyone - Does anyone know of any individual or firm the restores these assemblies? In advance, thanks!
  • Gerald C.
    • June 30, 1987
    • 1283
    Re: 1963 Parking Brake Handle Assembly Restoration???
    Mike,
    When you say "restore" what would you like to happen? If you remove the assembly, it's real easy to remove the handle and shaft from the housing. Just remove the stop pin and the shaft will slide out of the housing. Just watch the configuration of the pawls and springs inside the housing. Then you can sandblast and repaint it. As far as the handle is concerned, if the letters need painting, paint over the letters and after drying, use lacquer thinner and a thin rag and clean the handle of excess paint leaving the newly painted letters. Then reassemble. Check your AIM and other parts catalogue for detailed pictures. Just watch the placement of the brake light switch so when you reassemble, you wont break your back trying to get it positioned correctly.
    • Michael B.
      • February 1, 1985
      • 76
      • Harry S.
        • July 31, 2002
        • 5299
        https://www.corvettecentral.com/c2-6...%3d%26q%3dpawl
        • Gerald C.
          • June 30, 1987
          • 1283
          Mike,
          More than likely, your front parking brake cable needs to be replaced. I had to replace my two back cables as they were impossible to activate. Try starting with the new front cable. In addition, if you disconnect the front cable from the bracket under the car where it connects to the rear cables, are you able to move that bar freely? if so, it's probably the front cable. Let us know how you make out.
          Jerry
          • Michael B.
            • February 1, 1985
            • 76
            Thanks much, Jerry and Harry!!! Mike
            • Gerald C.
              • June 30, 1987
              • 1283
              You're welcome!
              • Bob W.
                • December 1, 1977
                • 802
                Jerry, Were at on the tube should the light switch be? Mine has been apart for a number of years. I"am waiting my spring and pawls to come.
                Thanks Bob
                • Harry S.
                  • July 31, 2002
                  • 5299
                  Thanks Bob
                  Bob, look at this eBay auction---> https://www.ebay.com/itm/30450658413...Bk9SR9TPy4yjYg
                  • Bob W.
                    • December 1, 1977
                    • 802
                    harry, thanks, that works.
                    Bob
                    • Harry S.
                      • July 31, 2002
                      • 5299
                      Bob
                      Save the pictures, eBay will delete everything after a month or so.
                      • Gerald C.
                        • June 30, 1987
                        • 1283
                        Harry, Great picture on Ebay that explains where this switch is located. Bob, when you're ready to install your brake handle, I would suggest removing your directional lever and steering wheel. It will be much more comfortable!!
                        • Bob W.
                          • December 1, 1977
                          • 802
                          Jerry, Thanks for the advice My column is not in at this time.
                          Thanks Again Bob
                          • Gerald C.
                            • June 30, 1987
                            • 1283
                            Good to hear!
