1963 340HP Ballast Resistor and Coil Test Ad Infinitum - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: 1963 340HP Ballast Resistor and Coil Test Ad Infinitum
    Fred what's the status of your original intermittent "power loss" issue?
    Did it re-occur?
    Rich
    • Frederick H.
      • August 31, 1983
      • 459
      Well, this past weekend, before cleaning the contacts on the coil and checking other connection, I found that the positive battery cable (spring ring) was super loose - never take the simple stuff for granted. I re-connected that cable and took it out with my son following for about 30 minutes - making hard turns, different levels of accelleration, all in 90+ degree Texas heat, with no failure. Will do it again this weekend with temps forecast around 100. It gets really hot inside this thing at those temps.
      Thanks for the follow up.
