1971 LT1 AX emissions label - NCRS Discussion Boards
    • 43247
    Re: 1971 LT1 AX emissions label
    You probably don't want to know how much it costs to have labels done, especially in small batches and with the correct materials.
    If it's $50 or less you're getting a deal; up to $100 would not surprise me for 1 label in order for them to break even.
    Patrick------
    I totally agree.
    • Larry T.
      Infrequent User
      • December 7, 2015
      • 7
      Patrick is spot on!
      • James G.
        • August 22, 2018
        • 800
        #18
        The original 71 label is printed in reverse on the back of acetate then flood coated white then adhesive applied.
        The layers from outer most to what is glued to the firewall ARE as follows
        Acetate
        Black print
        White flood coat
        Adhesive
        Having the print UNDER the protective acetate keeps the printing from being scratched or removed by brake fluid etc.
        Most glues will remove the original black printing and the white coat too, however SUPER GLUE WILL NOT, so if you have an original which is starting to lift... use a dab of superglue to hold it down.
        James A Groome
        1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
        1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
        My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
        Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
