Hello All,
Im back again looking for advice on re-assembling my intake manifold.
My goal is to install something that would not have to be redone later by another owner if he or she wants to have the car judged. The car is a 1973 Coupe with a 454, Automatic trans, A/C, PB, PS, PW. I have been looking though the JG and I dont see much info on the finishes on some of the parts. In the pix below you will see what I have so far.
I dont know what I should do with the hose fittings for the heater hoses, the bolt and lock washer for the EGR hold down and the stamped cover for the thermostatic choke spring. My understanding from one of other guys is that the EGR hold down bracket may have been finished in black oxide. Is this correct? I can get the black oxide finish, but what do you typically do to prevent corrosion? The black oxide will provide some rust protection, but not much.
Also, from the JG, I think the thermostat housing is supposed to be 3972128, not the one (3877660) shown in the picture. The caption below the picture on pg 159 is incorrect I think.
Any constructive criticism is welcome and appreciated.
Thanks for your help as always
Tom
Tom
