Source to Restore/Refinish/Replate Brake Backing Plates - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 694
    This might be a long shot...but I will never underestimate this resourceful group. I will be re-using my backing plates and am cleaning them up but would like to get them even better. Does anyone know a source that can restore/refinish/replate them? My understanding from the TIM&JG is the fronts are plated and rear are stamped galvanized. They have cleaned up pretty well via parts washing and Evaporust though some of the finish took a hit a little bit. See attached photos of my two rear plates...one before and one after. No, I do not want to replace them with others. These are the originals and have plenty of structural and form integrity. I can live with the aesthetics but want to see if I can do better. Not interested in any "judging" or award aspects just restoration to originality and preservation.
    Keith
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • James W.
    • December 1, 1990
    • 2671
    Re: Source to Restore/Refinish/Replate Brake Backing Plates
    I had my '65 brake backing plates replated in clear/silver zinc finish. They look good, not great due to the base metal corrosion which makes areas not a smooth as the original finish.
    Industrial Plating, Inc. here in Omaha, NE. did the work.
    James
      • 43263
      Keith
      Keith-----
      Check the area around the parking brake lever cut-out. This area often wears due to movement of the lever. I can't see it well enough in the photos.
      • Keith M.
        • January 17, 2021
        • 694
        Keith-----
        Seem ok to me. Even if they were not...can't imagine that would impact anything. Or do the slots act as a guide to keep the brake lever located to some degree?
        Keith
