Question on My Very Early C2(66) Retractor Pocket Holder Cover Black - NCRS Discussion Boards
  • Larry E.
    • 1692
    Got some points taken off for the above at the INCRS judging meet this last May. (Was a very well
    thought out meet thanks to Gary Bosselman) The ones on my very early(Sept.65 made) have
    some wear/torn/age on them. Question: Does anybody have and installed the new reproductions ones
    that can be bought through several venders. eg.>Zip-Corvette Central and etc. How close are they
    to the originals? Can one tell them apart? Picture Below. Thanks in Advance>Larry P.S. If they are not
    close to the originals will keep my aged originals on.
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1692
    Re: Question on My Very Early C2(66) Retractor Pocket Holder Cover Black
    Anybody??? Thanks>Larry
    Larry
    • Peter H.
      • April 1, 1980
      • 226
      Good Morning Larry. Personally I Would Stay With Your Aged Covers. Accept The Condition Deduction While Gaining On Originality Points
      i Like Seeing Original Parts. We Are Seeing Them Less And Less JMO. Peter 🇨🇦
      • Larry E.
        • 1692
        Hard to believe no one on this board has had any experience or input on these repro parts. It is was it is.
        Unless anybody else knows something on this I will take Peter"s(Above) advice and keep the originals
        (Which are old and worn) on the car and just take the hit on the points for Condition. Thanks>Larry
        Larry
        • Mike D.
          • July 31, 1996
          • 308
          That item has 2 other components on the line and worth 4 points total on both originality and condition. 2 points per side divided by 3 items does not yield a point deduction unless it is missing. Noted on judging sheet yes, deduction no.
          Mike Doty
          Intermountain Chapter Judging Chairman
          Region VIII Director
          • Larry E.
            • 1692
            Mike: Thanks for the response. Have you seen these new reproductions on the judging field? Are they even
            close to the originals? Just curious. Thanks Again>Larry
            Larry
            • Mike D.
              • July 31, 1996
              • 308
              I have not seen them. But if you are using CDCIF correctly, there is no deduction on small components on a line item with multiple items on that line. Keep it original. It was my pleasure to judge that bowtie candidate 67 at Rochester. Hearing stories about Uncle Henry's car from the owner help make it a very enjoyable experience.
              Mike Doty
              • Kent S.
                • February 1, 1993
                • 205
                I thought very early (like yours) '65's did not have retractors?
                • Don H.
                  Moderator
                  • June 16, 2009
                  • 2269
                  Hi Kent- His car is an early 66.. The retractor boot came out early in 65 production, as you say..
                  • Robert P.
                    • October 19, 2019
                    • 317
                    I have an early 66 car with an Oct 8th 65 build date and i purchased the correct repro belts along with the retractor boots and have never had an issue during judging, bought them direct from the company that makes them and then had the correct labels installed
                    Bob Peckham
                    • Kent S.
                      • February 1, 1993
                      • 205
                      Oops - my bad. Need to pay better attention to the title!
                      • Gary B.
                        • July 31, 1979
                        • 926
                        Larry
                        For concours judging, it's all about condtion. There is no originality points. It just needs to be pretty. Beauty contest. Witch hunt for dirt.
                        Use a heat gun taking the old ones off, preserve them for when you want to Flight judge the car.
                        Gb
                        • Larry E.
                          • 1692
                          Originally posted by Gary Bosselman (2575)
                          Larry
                          Gb
                          Gary: Thanks for the advice; will run it through Flight Judge at some point. Thanks again for doing all
                          work and the Time/Effort for such a nice meet in Pontiac. Do you think we will go to the same place
                          next year? I'll vote for that as a member. Larry
                          Larry
