Larry, I was very surprised that the ground-off 942 block that Colvin pictured in his book was installed in a April Corvette, and I have no theory about it.   It looks just like the one I had seen, but that was in a very early 67, around serial number 900.  Seeing one in an early 67 didn't seem strange at the time since I had not yet encountered the F-17-6 351 block.  I think the ground-off 942 block I had seen was cast in May.
I am still of the opinion that all 942 blocks were cast before the F-17-6 351 block. I don't think that any were cast later for the sake of the parts system. Later model year parts were used as replacement parts if they would fit with even with minor accommodations. Since most 427's were cast between 1 and 6 months before assembly at Tonawanda, there was storage area at least for 427 blocks. So some 942 blocks could have around to cover early 351 supply issues. The Colvin block must have been a extreme example of first-in last-out parts stocks or there was a mistake about the vin that was reported about it.
Here is another ground off casting example at same time period. I had a set of 858 heads that had ground off casting numbers with 391 casting numbers stamped on. They were the same font hand stamps (probably the same set) that were on the block I saw as well as the Colvin block. The were cast in mid and late June of 1966.
