Drip, drip, drip�.. - NCRS Discussion Boards
Drip, drip, drip�..
  • Jack W.
    • August 31, 1995
    • 126
    Drip, drip, drip�..
  • Keith B.
    • September 15, 2014
    • 1604
    • Jack W.
      • August 31, 1995
      • 126
      Originally posted by Keith Brodbeck (60464)
      study the AIM on all the heater box bolts/studs and make sure you remove them all. get a wide putty knife for the out side part to help remove. now is a good time to replace all the seals in the box, have a local radiator shop re-core the heater core and pressure test when done
      • John W.
        • December 15, 2015
        • 64
        https://www.forums.ncrs.org/showthread.php?131134-Help-with-1964-Stingray-heater-box-refurbishment&p=921729#post921729
        • Owen L.
          • September 30, 1991
          • 895
          • Frank C.
            • August 31, 2003
            • 171
            • Jack W.
              • August 31, 1995
              • 126
              • Mike T.
                • January 1, 1992
                • 570
                Mike T. - Prescott AZ.
                • Jack W.
                  • August 31, 1995
                  • 126
                    • 6961
                    • Jack W.
                      • August 31, 1995
                      • 126
                      • Jack W.
                        • August 31, 1995
                        • 126
                        • Jack W.
                          • August 31, 1995
                          • 126
                          Oddly, the core had a bead of silicone caulk applied on the passenger side.
                          I read a post that said to replace the foam seal on the duct door requires drilling out two rivets.
                          Has anyone done this?
                          Next, clean, refinish and reinstall?
                          Thanks, again.
                          Jack
                          • John W.
                            • December 15, 2015
                            • 64
                            • John W.
                              • December 15, 2015
                              • 64
