WCFB carb leakage issues - NCRS Discussion Boards
  • Richard F.
    Infrequent User
    • July 31, 1992
    • 11
    After a long run, I shut off and restarted my 61 (270, dual quad) and it backfired I think through the carbs. Anyway, I took off the air cleaner and there was gas dripping down in the secondaries on the front carb while the engine was running. I noticed gas coming out of the large gasgeted nut on top of the carb as well as the gasget to the air cleaner was wet. I tapped the top of that carb and it stopped dripping. Questions: 1-Was this the cause of the backfire? 2-Is there suppose to be gas coming through that front carb at idle? 3- What causes an erratic idle (600 to 1000 rpm without touching the gas)? 4- What is the procedure for adjusting the air/idle mixture and on both carbs? 5- Presuming it starts to drip again, where should I start? Thanks in advance for any help.................
  • Mark E.
    • April 1, 1993
    • 4610
    Re: WCFB carb leakage issues
    1- Probably.
    2- No.
    3 and 5- Tapping a carburetor that's overflowing with fuel is an old school way of "fixing" a sticking float/needle. I would start there as a possible cause.
    4. Don't know; I'm a Quadrajet guy. Is the procedure in the shop manual?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
