C3 Rear Underbody Mount Reinforcement Securement - NCRS Discussion Boards
  • Joseph S.
    • October 27, 2014
    • 192
    I am in the process of renewing the rear underbody mount reinforcements on my 1971 body. The reinforcements rivet to the car body with aluminum rivets. All seem to be good except I see no way to rivet the rear facing flange of the reinforcement without drilling a hole in the fiberglass cover (pictured).
    Of course I would rather not damage the body, so possibly someone has another method of securing the rear flange to the car body.
    Sorry but the images are orientated 90 degrees off.
    Thanks Joe
  • David H.
    • June 30, 2001
    • 1559
    Re: C3 Rear Underbody Mount Reinforcement Securement
    Joe
    Those mounts were installed prior to that covering fiberglass.
    I used a long drill bit and punched through a small hole in that back glass - inside to outside
    Used that hole to locate larger (about 1”) hole saw - providing access.
    Save removed piece to glass back in. A little mud and ……
    Dave
    Consider a SS cap screw with nylon lock nut and SS fender washers instead of trying to buck a rivet. Once glassed up, only you and I will know.
