torque spec - NCRS Discussion Boards
torque spec
  • Mel S.
    • August 31, 1992
    • 264
    torque spec
    I am installing the rear differential on my 66. Is there a torque spec. for the bolts for the rear frame differential crossmember?
    Mel
    • 15706
    Re: torque spec
    Have you looked in the '66 AIM?
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11363
      Re: torque spec
      Wow Duke you're up early! I have my AIM handy so I'll jump in.....
      Mel, the 4 bolts holding the top of the Differential to the Crossmember ?
      or
      the 2 bolts holding the Crossmember to the frame at the sombreros ?
      See AIM UPC 4 Sheet B3, Item 2 BOLT for either application.
      Next to Item 2 part#, ref the #2 inside the triangle, which is the torque spec, lower left on page, 55-65lbs/ft.
      But note the different part# lock washers at each location. Why different for the same size bolt? I have no idea.
      Rich
        • 15706
        Re: torque spec
        Correct torque for the two bolts that attach the axle cross member to the frame has always been somewhat of a mystery to me. From memory the '63 AIM says 35 lb-ft, but later AIMs (I dont' recall the years) specify 60-65 lb-ft.
        Since the weld nuts are usually not heat treated (because the weld temperature anneals them if they are hardened), I wonder it they will take that much torque without possible stripping.
        • Gary B.
          • February 1, 1997
          • 7065
          Re: torque spec
          or
          Rich
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11363
            Re: torque spec
            Hmm, now that you mention, I always cringed when tightening those 2 sombrero area bolts on all my chassis restorations. I think I've just used the "feel-good-and-tight" method for fear of stripping them.
            Thanks Gary, I knew there was some discussion at some time but forgot. Odd that the AIM still described the #446212 as a "L" washer. Likely a simple typo.
            Rich
            • James W.
              • December 1, 1990
              • 2671
              Re: torque spec
              I just installed the differential in my '65 last Sunday. The two differential crossmember bolts that bolt it to the frame had lock washers on them when I removed them, and the differential had never been out of the car. I believe I went with the AIM torque spec of 35 pounds. I'll have to verify that when I get home today.
              James
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11363
                Re: torque spec
                James
                Interesting,
                I just looked in the '65 AIM and those(4) bolts holding the Diff to the crossmember were Item 3, part# 454932(7/16x14, 1 1/8" long).
                Torque spec 45-55 lbs/ft.
                Item 2 sombrero bolts, part# 454933 (7/16x14, 1" long)
                Torque spec 55-65 lbs/ft.(WRONG! AIM shows 20-30 lbs/ft My typo)
                In 1966, Item 3(454932) was deleted, and then Diff to the crossmember used the same as the Item 2 sombrero bolts, part# 454933 (7/16x14, 1" long)
                I think they forgot to change the torque spec on these 4 locations, and just used the same reference as the other 2 sombrero locations. Those 2 go into steel weld nuts, the 4 for the Diff go into cast iron.
                Edit... The following statement may be wrong. See Post #15.
                Now I'm thinking the 1966 AIM torque spec is wrong(55-65 lbs/ft) for the 4 Diff to the crossmember bolts, part# 454933 (7/16x14, 1" long). I'm thinking it should be 45-55 lbs/ft. I think they missed the torque spec difference in the '65 AIM and assumed to use the same sombrero bolt highrer torque spec for the 4 Diff bolts.
                BTW, the 1967 AIM shows same info as 1966.
                Rich
                • Mel S.
                  • August 31, 1992
                  • 264
                  Re: torque spec
                  Thanks to all. Also some very interesting information!
                  Mel
                  • Mel S.
                    • August 31, 1992
                    • 264
                    Re: torque spec
                    The two bolts that bolt the crossmember to the frame at the sombreros.
                    Mel
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11363
                      Re: torque spec
                      Mel
                      Mel, Deep in my earlier post I said.... Torque spec 55-65 lbs/ft
                      But as mentioned, you want to make sure you don't strip the embedded weld nut threads, so you may want to go on the relaxed side of the spec, or less. Best to clean the threads of the weld nut with a thread restorer(not a Tap), and if you apply any Anti-Seize on the bolts, go even less on the torque.
                      Rich
                        • 15706
                        Re: torque spec
                        Gravity pretty much holds the axle cross member to the frame, so I don't think those bolts need much torque, but like the main battery turrets on the battleships Bismark and Yamato, it might fall out if the car capsizes.
                        • James W.
                          • December 1, 1990
                          • 2671
                          Re: torque spec
                          I took a picture of the applicable page in my 1965 AIM that covers the differential crossmember installation. As you can see, the torque specification for the two bolts is 20 to 30 lbs./ft. I usually shoot for the mid range of the torque specification so I torqued them to 25 lbs./ft.
                          James
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11363
                            Re: torque spec
                            James
                            James, I'm glad you checked that. I misread my 1965 AIM page. I corrected my earlier post re 1965.
                            However..... The 1966 AIM states 55-65 lbs/ft for that same crossmember to frame bolt location. Something is in error. But 25 lbs/ft seems a bit shy for a 7/16-14 bolt to me.
                            At this point I don't know what's right and what's wrong.
                            1966 AIM
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11363
                              Re: torque spec
                              The plot thickens.
                              Crossmember to frame sombrero bolts #454933.... This was a Grade 8 bolt.
                              1963 Torque spec was "initially" stated as 20-30 lbs/ft, then it changed to 55-75 lbs/ft on 4/23/63
                              1964 Torque spec 20-30 lbs/ft
                              They realized the error in March of 1963, but it never got translated to the 1964 OR 1965 AIM. Then it got noticed.
                              I believe the 1964 AIM is wrong, as well as the 1965 AIM is wrong, and it got corrected in 1966/67 to 55-65 lbs/ft)
                              They got this confused for years. Summary: I believe the correct torque spec is....... 55-65 lbs/ft. No way would I trust 20-30 lbs/ft.
                              Rich
                              Ref AIM pages
