'94 Seat belt IS JG correct ? - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 524
    My '94 Convertible has the following seat belts- they sure look original to me. Date decode ?
    GM 10251979 TRW Model H91-12 313931L driver are these correct, do not match JG
    Trying to upload photo
    THANKS
  • Pat F.
    • April 1, 1981
    • 856
    Re: '94 Seat belt IS JG correct ?
    Bob, the seat belt section is going to addressed in the revised 1994-96 Judging Manual. When that manual is ready, I have no idea.
    If you have your Build Sheet, go to Block 42 and you will find two sets of four-digit numbers. In your case one of the numbers should be 1979. This is last four digits of your GM number. This is the only way I am aware of determining the correct number. Someone else may have another method. Again, rely on the build sheet. In the past Chevrolet printed in the respective Factory Service Manual a complete listing of seat belt numbers. However, starting in 1994 they no longer provided that information,
    PAT, Central New Jersey and Florida Chapters
    • Pat F.
      • April 1, 1981
      • 856
      This is a follow up to my previous post. As you can see on my build sheet in Block 42 I have the numbers 9791 and 9792. The seat belt tags show the last four digits of the GM number as 9791 and 9792. My 1995 Corvette has a build date of August 4, 1994. This is one of the first production line units for the 1995 model. I am attaching some photos for your review. If anyone else has a method of identifying the correct seat belt numbers, please let us know. I always recommend bringing your build sheet when you have your C4 judged. It could resolve a lot of questions. I hope this helps out. Any comments, as usual, are greatly appreciated.
      • Bob B.
        • January 31, 2007
        • 524
        Pat, I appreciate your reply. fortunately the Corvette Museum not only can provide the original window sticker but also the build sheet,
        so documenting the proper seat belt number is easy. Same with proper battery model- the JG differs from what is on my build sheet.
        When I get my '94 judged I want to have my back up in writing so I get correct judging. By the way, I suppose a build sheet is still on the gas tank, is anybody finding build sheets stuck away anywhere else on '94 era cars? And again, THANKS Bob
        • Pat F.
          • April 1, 1981
          • 856
          Bob, one of the locations of the original build sheet is over the right rear side of the gas tank. It is not glued on but tucked under the gas tank straps. To get it down you would have to loosen the straps.
          There are other locations on the C4 Corvette where the build sheet is supposed to be stuffed, but I haven't found it on my 1995.
          I am attaching some photos, fortunately, none are my 1995 Corvette.
