Instrument lights - NCRS Discussion Boards
Instrument lights
  • Michael G.
    • November 12, 2008
    • 2158
    Instrument lights
    My 65 suddenly has no instrument lights. Normally in such situation I check the tail lights, then, if they’re out, I change the fuse. This time, the tail lights still work and the fuse looks OK. Before I get my hands too dirty, is there a simple explanation for this? (The rheostat has no effect)
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Jim L.
    • September 30, 1979
    • 1817
    Re: Instrument lights
    Mike, my bet is that the rheostat wire has gone open circuit. A quick check with a VOM or DVM will confirm that (or not).
    • Michael G.
      • November 12, 2008
      • 2158
      Mike
      • Jim L.
        • 1817
        Originally posted by Michael Garver (49693)
        Thanks Jim, I don’t much like messing under that crowded A/C dash, but I’ll drag out my meter…
        I definitely get that, Mike, and I don't blame you.
        FWIW, the same thing happened to the instrument lights on my '54. I jumpered around the rheostat and lights returned. Since I don't have the car judged, I just left it that way.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11370
          The 2nd from bottom fuse TAIL LPS is for the tail lights(Brown wire), but that also feeds the dash lights from the HL switch rheostat(to Dark Green wire), back to the Fuse Panel, via the PANEL LPS fuse, whose output is Gray to all of the lamps.
          Did you check that PANEL LPS fuse, and with a voltmeter on both ends of the fuse holder clips with respect to ground?
          Do the dash lamps go FULL Bright if you turn the knob fully CCW just before(or after) the "click" to illuminate the Courtesy lamps?
          If FULL Bright does NOT work, then the PANEL LPS fuse or connections are faulty.
          If FULL Bright works, then the HL switch rheostat is open.
          See THIS Thread for more info and potential repair process.
          Rich
          '66 below but '65 similar
          Last edited by Richard M.; May 5, 2023, 09:12 AM. Reason: wire colors & fuse names
