71 LT-1 - Diagnosing Holley Leak - NCRS Discussion Boards
  • Mick D.
    • January 22, 2022
    • 159
    Hi friends,
    I solved my leak for a while by tightening the fuel inlet fittings and it was leaking quite a bit at that point. Now it leaks less, but from the front.
    The 2nd video is after I shut it off.
    Any ideas which tightening I need to solve this - or do I need new gaskets?
    Appreciate any input,
    Mick
    Check out the NCRS Points Tabulator/Calculator Helper
    Caretaker of 1971 LT-1 #16326 - Chapter Top Flight 2022
    1971 LT-1 : Direct links to outside, interior & under dash, TI ignition parts
    1971 LT-1 : Full date codes inventory
  • Mick D.
    • January 22, 2022
    • 159
    Re: 71 LT-1 - Diagnosing Holley Leak
    I should add, this seems to go away after it has warmed up and driven around the block - either that or it is so little that it just evaporates from engine heat. After a trip around the block (10 minute drive) I did not see any leaks whatsoever on return or after stopping.
    • Owen L.
      • September 30, 1991
      • 882
      Difficult to tell exactly but it appears it could be the accelerator pump diaphragm/lever cover or perhaps the bowl screw right above it. Near the end of the second video, it seems like there's right to left movement of the gas to the corner before it drips off. For this reason, I'm leaning toward the bowl screw.
      The bowl screws should have a sealing washer/o-ring right under the head. For my Holley, I find that these screws can always be snugged a quarter to half turn - they just seem to self loosen a tad over time. If it's the accelerator pump cover, the only way to adequately tighten the cover is to remove the carb. The pump is simple and inexpensive to swap out in case it's the culprit.
      • Mick D.
        • January 22, 2022
        • 159
        Hey Owen - Thanks for looking, I will check those screws. It would seem that as I chase the leak it is moving to the path of least resistance
        • Mick D.
          • January 22, 2022
          • 159
          • Owen L.
            • 882
            Glad it worked. I've considered using a Loc-Tite formulation on them but just haven't investigated which one or even if it's advisable.
