1967 Manual brakes - NCRS Discussion Boards
1967 Manual brakes
  • John C.
    Infrequent User
    • October 2, 2020
    • 11
    1967 Manual brakes
    I recently purchased a very original 1967 L79 with an aftermarket power brake master and booster. Being a numbers matching factory original guy and this being the only item not original to the car, I purchased a DC coded master cylinder and removed the aftermarket one along with the booster. I also replaced the brake pads, checked the condition of the rotors and completely bled the system with DOT 4 fluid. I was very surprised to see how poor the braking is on the car. I do not believe that I can lock the brakes given how much pedal pressure I need to apply just to get the car to slow down. Am wondering if this is normal? Any input to this thread is welcome and appreciated.
  • Leif A.
    • August 31, 1997
    • 3643
    Re: 1967 Manual brakes
    John,
    Did you bench bleed the new master cylinder? It sounds like there is air in the system. As simplistic as these brake systems are, they can be a bit cantankerous when it comes to bleeding the system. I, also, have a '67 L79 with factory power brakes and I can assure you they work every bit as good as a modern power braking system.
    Leif
    • Mark F.
      • July 31, 1998
      • 1563
      Originally posted by Leif Anderson (29632)
      John...I, also, have a '67 L79 with factory power brakes and I can assure you they work every bit as good as a modern power braking system.
      John,
      I agree with Leif.
      I have factory PBs on my '67 L-68 and they work like a charm even after 20+ years post re-build; bench bleed and gravity bleed.
      thx,
      Mark
      • Donald H.
        • November 2, 2009
        • 2586
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • Mark F.
          • July 31, 1998
          • 1563
          Originally posted by Donald Harris (51003)
          I may be wrong
          Don,
          No you're not wrong.
          Glad to hear the same applies to non-power.
          Best brakes I've ever had on a car that was made before 1967 !
          that's including my 1938 Ford coupe w/ CABLE brakes! - Absolute WORST brakes ever ! several times I had both feet pushing down on the brake pedal (one on top of the other) - and both hands grabbing the underside of the metal dash (yes I left go of the steering wheel) - and still barely came to a stop inches away from a car that stopped suddenly in front of me !
          thx,
          Mark
          • Rocco S.
            • December 21, 2013
            • 180
            I agree with Don. I too have a 1967, L79 non-power brake car. I replaced the original MC with a GM exact reproduction unit and calibers with Lone Star S/S sleeved, "O-ring" calibers and the system has been perfect. I bench bled the MC, used a Mity-Vac starting at the right rear wheel and moved forward. Finally, finished with the traditional pump, pump, pump and hold at each wheel. That was over 5 years ago and brakes are still excellent. Albeit, they need a little more foot effort since they are not power.
            ROCCO SCOTELLARO
            1967 Lynndale Blue/Black Coupe L79, M21, G81 (3.70:1), A31, A82, C60, K66, N11, U69
            • Donald H.
              • November 2, 2009
              • 2586
              I had a 66 with power brakes and mostly the difference between it and 67 with non-power brakes was the pedal pressure needed. The 67 will stop on a dime and the 66 would stop on a dime and give you some changes!!
              Don
              Don Harris
                • 43246
                Originally posted by Mark Francis (30800)
                Don,
                Mark------
                The automotive industry did not universally go to hydraulic brakes because cable-operated brakes worked just as well.
                • Keith B.
                  • September 15, 2014
                  • 1588
                  in 67 both standard brakes and power brakes used the same master cylinder. and when both are up to OEM specs they both should lock up the wheels.
                  • Mark F.
                    • July 31, 1998
                    • 1563
                    Mark------The automotive industry did not universally go to hydraulic brakes because cable-operated brakes worked just as well.
                    Hi Joe,
                    Yes and Mr. Ford was one of the last to switch over in 1939.
                    The problem I had with cable brakes (unlike solid rod versions on Model As - I had one of them, too) was they stretched.
                    Cable shorteners were illegal for Pennsylvania's twice-a-year inspections back then (early '70s), but even with "new" cables it was almost impossible to keep them (at least mine) in good adjustment w/o them. Even w/ a flathead 85hp V-8, the car only weighed ~2,600 lbs. - a lot less than a C2 Vette. Those were the days, eh ?
                    thx,
                    Mark
                      • 15706
                      This is a common issue. In a 1965 SAE paper it was stated that Chevrolet decided to not include a vacuum booster in the new disk brake system as a cost saving measure, and they established a design criterion that a 1g deceleration rate require 120 pounds of pedal force. Of course, OE tires of the era would at best, on an ideal surface, generate no more about 0.9g.
                      All modern cars have power brakes and a 1g stop requires on the order of 25-40 pounds of pedal force.
                      Twenty-twenty hindsight tells us that Chevrolet's cost saving measure was ill-advised, but, remember, in the mid-sixties, a lot of older cars did not have power brakes, so drivers were accustomed to higher brake pedal force than today.
                      The same can be said about the steering. We've become accustomed to power brakes and steering for 40-50 years, so getting into any old car with no power assist can make it steer like a "truck" and have "no brakes".
                      The solution is either get used to it, spend more time in the gym doing squats with weight and pull-ups, or "upgrade" to power assist.
                      • John C.
                        Infrequent User
                        • October 2, 2020
                        • 11
                        Leif, Thank you for response, yes I did bench bleed the master. I do get a good pedal, just not a very good stopping power. I surely cannot lock up the brakes. Would you say that even with a good pedal there could be air in the lines?
                          • 43246
                          John------
                          Yes!
                            • 43246
                            Duke------
                            I ordered my original owner 1969 with standard, non-power brakes. In 1973 my brother bought a new 1973 Corvette. This car had power brakes. I drove it a few times. I could not discern any braking difference between the two cars.
                            • John C.
                              Infrequent User
                              • October 2, 2020
                              • 11
                              Hello Don, Thank you for responding, as I stated in the original thread, I removed the aftermarket power brake master and booster and can say that the braking was not so great with the power system installed. Seems like there is something else going on here. Would you know if the proportioning valve would cause poor braking if defective?
