71 LT-1 Exhaust same as Service Replacements for 67-68 and 71' 454? - NCRS Discussion Boards
    • 15641
    #46
    Re: 71 LT-1 Exhaust same as Service Replacements for 67-68 and 71' 454?
    Originally posted by Mick Dreeling (68813)
    Joe, I am also confused, so I am glad it is not just me . I actually did think that it didn't look swaged myself, but had not seen enough parts to know. If it is one piece, it seems to have been squashed rather than 'pulled' like what I am used to seeing on LT-1s. Here is the link to the part. It does seem to have a GM sticker on it. Maybe the extra photos will give you more clues.
    When I durst looked at that image I thought that first line was the point at which the swag operation ended and the "step" onto the larger diameter began. Today I am less sure. But it certainly doesn't look like the usual welding operation either.
    I would now rate it an "I don't know" I think one would need a higher resolution photo with better lighting.to be sure.
    • Mick D.
      • January 22, 2022
      • 159
      #47
      Hey Terry, I have asked the seller for a better picture of the flare, we will see. From the sticker (assuming it is correct), it looks like this is a SERVICE part for 334926from 1973. I'm really curious. As you said, it does not look at all like what is typical of what I expected for the flare.
      Check out the NCRS Points Tabulator/Calculator Helper
      Caretaker of 1971 LT-1 #16326 - Chapter Top Flight 2022
      1971 LT-1 : Direct links to outside, interior & under dash, TI ignition parts
      1971 LT-1 : Full date codes inventory
        • 43290
        #48
        • Mick D.
          • January 22, 2022
          • 159
          #49
          Thanks for the clarification Joe. This is great info.
          Based on everything that we just discussed, I am currently looking at a entire 1968 system minus mufflers that looks in good shape and might be a fit. It has all the swages and bends all the way down , and all 4 parts are aged evenly. (See below)
          • Paul D.
            • September 30, 1996
            • 491
            #50
            The rear pipes pictured above have either been cut for use with replacement mufflers or are service replacements. May just be the photo, but they appear to have areas that are more silver looking than I would expect to see on original steel pipe. Also, looks like mufflers installed on those pipes were 2" adapted to the 2.5" pipes. Chip.
            • Mick D.
              • January 22, 2022
              • 159
              #51
                • 43290
                #52
