1970 Engine Build Date Versus Serial Number - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 827
    Serial Number Engine Build date Car Built
    7023 03/02 03/18
    7040 02/23 03/18
    8638 03/02 05/08
    Is this typical or maybe strike related?
  • Ralph S.
    • February 1, 1985
    • 935
    Re: 1970 Engine Build Date Versus Serial Number
    1970 vin 6242 2/27 03/10 350/370 Lt-1
    • Mark F.
      • July 31, 1998
      • 1594
      7023 03/02 03/18
      7040 02/23 03/18
      8638 03/02 05/08
      Bob,
      Big Blocks, Small Blocks or a mix of both?
      Also check out this thread
      https://www.forums.ncrs.org/showthre...1969-big-block
      thx,
      Mark
      • Michael H.
        • December 1, 1987
        • 732
        7023 03/02 03/18
        7040 02/23 03/18
        8638 03/02 05/08
        Bob,
        The strike started on Sept 15, 1970 until Nov 23, 1970 and lasted for 67 days. It shut down over 145 plants and suppliers in the US & Canada as it impacted over 400,000 UAW workers. My 71 Chevelle SS 454 which was built on Dec 16, 1970 in Arlington, TX. It has many parts including the engine ( cast date August 9th and build date Sept 8th ), tranny, rearend, etc that were built in August and early Sept of 1970. Parts just sat as there was no production going on for 67 days.
        Mike
          • 15631
          Originally posted by Michael Hanley (12271)
          Bob,
          Mike
          Mike
          The work stoppage you are referring to was not appropriate to 1970 Model Year Corvette production. It refers to 1971 Corvette Model Year production which began August 17, 1970 (A17).
          1970 Corvette production Began January 5, 1970 (A06) and ran until July 31, 1970. (G31) I suspect production ran a day or two beyond July 31, but the trim tags we have found in the last 40+ years are stamped G31.
          The work stoppage during the 1970 Model Year ran from April 7, 1970. (D07) to May 5, 1970 (E05)
          BTW: That sounds like a nice Chevelle. I love those cars too. I have a 1967 Chevelle that is not quite stock.
          • Michael H.
            • December 1, 1987
            • 732
            Mike
            1970 Corvette production Began January 5, 1970 (A08) and ran until July 31, 1970. (G31) I suspect production ran a day or two beyond July 31, but the trim tags we have found in the last in the last 40+ years are stamped G31.
            Terry,
            You are correct that 67 day strike impacted 1971 cars not 1970.
            Mike
            • Mark E.
              • April 1, 1993
              • 4607
              1970 #12931
              LS5 block casting H 25 9 (08-25-1969)
              Head castings D 15 70 (04-15-1970 for both of them)
              Intake casting E 8 70 (05-08-1970)
              Engine assembly (stamp pad) 0608
              Trim tag F22 (06-22-1970)
              So engine assembly was over nine months after block casting, but only two weeks before final assembly. Who knows if this is due to a strike, rework, or something else. All of the above is believed original to the car; see: https://www.forums.ncrs.org/showthre...k+casting+date
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Bill B.
                • August 1, 2016
                • 305
                I'll join in the fun and share:
                Engine Cast = F 27 0 = June 27, 1970
                Engine Assy = V0629 = June 29, 1970
                Vehicle Assy = G16 = July 16, 1970
                Bill Bertelli
                Northeast and Carolinas Chapters Member
                '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
                • Mark F.
                  • July 31, 1998
                  • 1594
                  Here's the data so far sorted by VINs provided...(sorry, vBulletin doesn't like imported tables very much)...
                  VIN deriv Engine Cast Engine Assy Days After Cast BBD (Car Assy) Days After Cast Days After Engine Assy
                  6242 2/27/1970 3/10/1970 11 not listed NA NA
                  7023 3/2/1970 3/18/1970 16 not listed NA NA
                  7040 2/23/1970 3/18/1970 23 not listed NA NA
                  8638 3/2/1970 5/8/1970 67 not listed NA NA
                  12931 8/25/1969 6/8/1970 287 6/22/1970 301 14
                  ??? 6/27/1970 6/29/1970 2 7/16/1970 19 17
                  thx,
                  Mark
                  • Justin S.
                    • July 3, 2013
                    • 305
                    Terry,
                    Did work resume on the 5th or 6th?
                    • Ralph S.
                      • February 1, 1985
                      • 935
                      6242 needs to be corrected engine assembly was 2/27 build date on trim tag was 3/10 I do not have the casting date.
                      • Mark F.
                        • July 31, 1998
                        • 1594
                        Sorry, Ralph,
                        correction incorporated below...
                        6242 NA 2/27/1970 NA 3/10/1970 NA 11
                        thx,
                        Mark
                        • Mike E.
                          • February 28, 1975
                          • 5141
                          • Mark F.
                            • July 31, 1998
                            • 1594
                            Interesting, Mike...
                            here's your car added to the mix...I used your ship date instead of the BBD.
                            it would be cool if we could get Ralph's cast date
                            6243 3/3/1970 3/4/1970 1 3/11/1970 8 7
                            thx,
                            Mark
                            • Mike E.
                              • February 28, 1975
                              • 5141
                              [QUOTE=Mark Francis (30800);931341]Interesting, Mike...
                              Ralph's was an LT-1, mine an L46, FWIW.
