Need help, left my TIMJG at home & came across this M/C - NCRS Discussion Boards
    • November 1, 1998
    • 145
    Does/is this M/C look correct for a '63 coupe with a Nov. 1 '62 build date? Thanks
  • Harry S.
    • July 31, 2002
    • 5342
    Re: Need help, left my TIMJG at home & came across this M/C
    The list below is believed to be the only dates on 63 master cylinders. With a 11/1/62 build date, the ones highlighted in black are your choices.
    I think the K23 and K31 is too close to your build date.
    If you have power brakes you need one with the additional bleeder. If you can't find one, you can have it tapped to add the bleeder. That's all GM did.
    G-11-2
    J-10-2
    J-20-2
    K-23-2
    K-31-2
    L-30-2
    M-29-2
    A-5-3
    A-9-3
    A-15-3
    B-22-3
    C-25-3
    C-26-3
    • Peter H.
      • April 1, 1980
      • 229
        • November 1, 1998
        • 145
        G-11-2
        J-10-2
        J-20-2
        K-23-2
        K-31-2
        L-30-2
        M-29-2
        A-5-3
        A-9-3
        A-15-3
        B-22-3
        C-25-3
        C-26-3
        Thanks Harry but you got me confused, would not the date code be a "C" for a Nov '62 cast date and "J" being '63 cast date? The date code looks to me like "C102" but could be my eyes and still learning...Thanks Jack
        • Harry S.
          • July 31, 2002
          • 5342
          Jack, parts dates start in January. So C 26 3 is March 26th, 1963. Likewise, G 11 2 is July 11th 1962. They did not use the letter I​.
            • November 1, 1998
            • 145
            Got it...Thanks so much for your help...Jack
            • Harry S.
              • July 31, 2002
              • 5342
              From your picture I can not read the date on your MC, what do you see?
                • November 1, 1998
                • 145
                Good question..."C", "B" or "G" is my guess. Going to go look at it tonight...Jack
                Per your table "G" would be a match...correct?
                • Harry S.
                  • July 31, 2002
                  • 5342
                  If the last three numbers are 10 2 or 20 2, then the first letter is a J​. J is good also for you.
                    • November 1, 1998
                    • 145
                    Thanks to everyone for the help. As it turns out it was a L 30 2 cast date witch won't work for me. To bad as it was in good shape other than surface rust, can't win them all...thanks Jack
