[QUOTE=Duke Williams (22045);930749]
The Merc uses bolts, not nuts on studs to mount the wheels. Over the years if I needed to remove the wheels for maintenance I never had a problem getting the wheel over the hub, lining up the holes, holding the wheel in place with one hand and starting at least one bolt with the other hand, but last year when installing the wheels after a brake fluid flush I could not do the above due to loss of shoulder strength.
I recalled that the tool kit had a stud that you install into the hub thread, then you can hang the tire on the stud and get the bolts started. I had never used in before, but I tip my hat to the Mercedes engineers that anticipated by loss of shoulder strength 35 years down the road.
I also recommend coating the wheel studs/bolts with anti-seize compound, and also on the mating surfaced of the fasteners and wheel. Have you ever heard "squeaking" as you torqued a wheel fastener? That's the sound of the steel screaming in agony due to the galling pain. Anti-seize will eliminate the pain and allow the fastener to smoothly come up to torque and the final value will be much more consistent than if the threads are dry.
Duke[/QUOTE
Hi Duke
I hear you with shoulder strength. Starting at age 50, you lose 10% muscle mass every decade. I'm 82.
I didn't think you were supposed to lubricate wheel studs/nuts. They are dry right from the factory. Think it is the possibly of coming lose with the shock/vibration wheels encounter - No locking devices.
Dannn
Duke[/QUOTE
Hi Duke
Dannn
