Question on hose replacement for the 66 Corvette Windshield Washer Nozzles - NCRS Discussion Boards
  • Larry E.
    • 1677
    Here we go> Can one put on new hoses for the above without taking off the Wiper Arms? I noticed
    when the arms are raised(maintenance position for changing the inserts) there is a little room between
    them and the grills which would be unscrewed and raised up a bit. I thinking possibly with long needle
    nose pliers. Has anybody done this?? Thanks in advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1677
    Re: Question on hose replacement for the 66 Corvette Windshield Washer Nozzles
    Anybody?? Need Advise. Thanks>Larry
    Larry
    • Don H.
      Moderator
      • June 16, 2009
      • 2258
      Larry
      why don't you give it a try and report back here with your results?
      Maybe using these. $6 from HF
      • Larry E.
        • 1677
        [QUOTE=Don Hooper (50543);930918]Larry
        FFCADECD-C8AF-4506-9432-BFD50E6F65E0_1_201_a.jpg[/QUO
        Don: Thanks for your response. Yes I do have a pair of these. Also thinking of finding/getting a "BIG"" pair of
        tweezers that could go around the top of the grill slots. Why do want to stay away from taking the Wiper Arms
        off? When I replaced mine(not originals) WITH ORIGINALS>>IT WAS AN ALL OUT BEAR. So easy to scatch
        the paint in that area. In the mean time if anybody else has thoughts on this subject PLEASE COMMENT>Larry
        Larry
        • Don H.
          Moderator
          • June 16, 2009
          • 2258
          To my mind, your way sounds much more hazardous to paint than simply using this specially designed tool. $6 on Amazon
          • Mark F.
            • July 31, 1998
            • 1524
            Originally posted by Don Hooper (50543)
            To my mind, your way sounds much more hazardous to paint that simply using this specially designed tool. $6 on Amazon
            Larry,
            I agree with Don. I'd use the tool designed to remove them from their splines.
            Here's how I do it:
            Good luck !
            thx,
            Mark
            • John F.
              • March 23, 2008
              • 2408
              Remove the wipers and the grills. Keep a magnet standing by so you don't drop the screws down the black hole. Just take your time. It is pretty easy.
              • Larry E.
                • 1677
                Update: Making some progress; have the new hose(on drivers side) routed through grommet. Will try to
                hook up to nozzle. (Have the nozzles free & rotating) This is w/o taking the wiper arms off which I will refuse to do.
                BTW the second tool shown above(small handle with tooth on end)WAS TOTALLY USELESS WHEN I TOOK OFF
                THE NON-ORIGINAL ARMS AND PUT ORIGINALS ON. I had to make my own tool which resembles a small
                crow bar. It has way more leverage and better angle. Even with the new tool the old ones ONLY came off after using
                CRC freeze off and PB B'laster Penetrant. This was done by drilling a hole on top of the old arm "cap" and to put
                the Penetrant on top of the spline. This is why I WILL NOT mess with taking off the ORIGINAL ONES. Too risky
                for damage. I'll let you know what happens. IF ONE DOES NOT HAVE PATIENCE; DO NOT ATTEMPT WHAT
                I AM TRYING TO DO. Thanks>Larry
                Larry
                • John F.
                  • March 23, 2008
                  • 2408
                  I never heard of anybody having such trouble. I have been using a wide blade screwdriver with a rag under it since high school. Good luck!
                  • Larry E.
                    • 1677
                    John: Me neither but every car is different how it was stored and used for 50+ Years. Mine had much more
                    corrosion then most. I cleaned the corrosion off as best I could but my splines increased in size ever so
                    small. Larry
                    Larry
                    • Larry E.
                      • 1677
                      Update>Ok everything installed W/O taking off the arms. Now have discovered I have clogged nozzles.
                      (Nozzles do swivel OK) When compressed air is put into the hose very little(if any) comes out the nozzle.
                      I have started another thread on this subject. Please read. BTW>Thanks to all that have responded>Larry
                      Larry
                      • John F.
                        • March 23, 2008
                        • 2408
                        Get a pin from your wife's sewing kit, stick it thru the nozell a couple times and should be good to go. I have done this on numerous cars.
                        • Robert B.
                          • May 20, 2013
                          • 39
                          The tool makes this dead simple. You stand more of a chance damaging something trying to get cute with long nose pliers.
                          • Mike M.
                            • May 31, 1974
                            • 8383
                            rather than invade the wife's sewing basket, i use the tool to clean oxygen-actylene tips. start with the smallest wire then advance to larger wire sizes till you hit a brass color on the wires. mike mccagh
                            • Larry E.
                              • 1677
                              Houston;We got lift off! OK; everything put back together with New Hoses(Kit bought from Paragon) and both sides
                              working well to my surprise. Never thought a 55+ year car's pump would work. Just primed it and it worked great. This
                              was all done W/O taking off the arms of the wipers.(Trico Originals) No damage done either. Getting close now for
                              judging in May. Will be testing for "Operations". Thanks to all that replied; took a little bit of info from all. Larry
                              Larry
