Alternator Rotor Shaft Thread - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    I need a die to clean up the threads on a typical C2 alternator, the Delco 10dn. Through research I have determined that the shaft thread is imperial decimal 0.668 inch - 20 thread per inch.
    I have searched and not been able to find this size die. I've tried 11/16 (0.6875) and 17MM (0.6693), but neither of these are correct.
    I've found a number of references to the 0.668-20 including a generator/alternator part supplier that said the shaft was 0.668-20.
    Anyone know of a source for somewhat odd size taps and dies?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • David H.
    • June 30, 2001
    • 1571
    Re: Alternator Rotor Shaft Thread
    Don
    Don
    When you say you've "tried" an 11/16 (0.6875) die, exactly what was the problem?
    You indicated a need to clean up those threads. Is the problem those damaged threads are preventing die from starting?
    Seems like a difference of 5 ten-thousandths should not be a deal breaker.
    I've checked Murray Split Die Repair System, but can't find where they have an 11/16 20tpi split die for sale.
    Dave
      • 43290
      Don
      Don------
      The thread size for all 1962-82 alternators is 5/8-20. It's an uncommon thread size but it is available. Try eBay,
      SEE UPDATE BELOW
      • Peter H.
        • April 1, 1980
        • 231
        Hello Donald. Have You Thought Of Using A Thread File. I Have Used Them To Clean Up A Damaged Thread. Usual Area Is At The Tip Of The Bolt/Shaft. Hope This Helps. Peter ๐Ÿ‡จ๐Ÿ‡ฆ
        • Scott P.
          • April 30, 1992
          • 178
          Don, a 11/16 - 20 die is what I used to fix the alternator threads.
          A company called Wholesale Tool is my source. Their part # 9163-0245 and is about $11. It is a 1.5" OD round die.
          WTTool.com
          If you would like Ill just send you mine and you can return it when done.
          Scott Fogaley@sbcglobal.net
          • Donald H.
            • November 2, 2009
            • 2594
            I'm pretty confident that the thread size is .0668-20. I've found multiple sources that indicate this as the size.
            From an online generator/alternator parts supplier listing for pulley nuts: 842700 - Alternator Pulley Nut, 5 Pack, for Delco and Ford Alternators, .668-20, uses 15/16 socket, 5/16 thick, For 17mm shaft
            I have an 11/16"-20 die which I can make work. But I will likely also have to tap the nut to get a good fit.
            I used the die to cut new threads in another old rotor shaft (17mm) and while I could get the correct alternator nut to screw on, it was difficult. If I'm unable to fine the 0.668-20 die I'll go with the 11/16"-20.
            Don
            Don Harris
              • 43290
              I use the die to cut new threads in another old rotor shaft (17mm) and while I could get the correct alternator nut to screw on, it was difficult. If I'm unable to fine the 0.668-20 die I'll go with the 11/16"-20.
              Don
              Don------
              An update:
              GM says that the alternator shaft thread size is 5/8-20 for all 1953-96 generators and alternators. I have found this thread size in numerous GM-sourced references. However, in this case GM is INCORRECT. I have a 5/8-20 re-tapping die and it is clearly too small to engage the alternator shaft threads.
              I'm not so sure that an 11/16-20 die, which is uncommon but also available, is the correct one, either. I figure this must be a "special" thread. Why such a thread was used escapes me, though.
              As far as where one could obtain the correct size die, I have no idea. If you want to take it that far, you might be able to contact a commercial alternator rebuilder and ask them if they know where to obtain such a die.
              • Tom L.
                • October 17, 2006
                • 1439
                I went through this a few years ago when I boogered up the threads on my newly rebuilt alternator by Ken Bruno. I wasn't happy. Finding a die seemed impossible. I was able to find a thread file and with a little effort it cleaned up just fine.
                • Donald H.
                  • November 2, 2009
                  • 2594
                  I did clean up the threads with an 11/16-20 die. The standard nut, which is 0.668-20, will start but will not go on without quite a bit of force. So rather than force it with a wrench, I ordered a 11/16-20 tap to re-cut the threads on the nut. This should work, I hope.
                  Don
                  Don Harris
                  • Scott P.
                    • April 30, 1992
                    • 178
                    Guys, Post #5 tells you what, where, how much. Scott
                    • Donald H.
                      • November 2, 2009
                      • 2594
                      Just to close out this thread --
                      I did rethread the rotor shaft with the 11/16-20 die; however, the stock 0.668-20 nut would not go on by hand. I didn't what to force it with a wrench and possible destroy the threads on the rotor shaft or the nut. I ordered a 11/16-20 tap and proceeded to rethread the nut. The nut now goes on the shaft effortlessly and the threads all look good.
                      Don
                      Don Harris
