1967 hood pins and associated retainers - NCRS Discussion Boards
  • Brian E.
    • May 28, 2018
    • 287
    On page 173 of the current 67 judging guidebook, it says:
    The hood pins and associated retainers, located on the rear corners of the hood, are cadmium or zinc plated with a semi-gloss black painted spring. Hood pin retainers on St Louis built bodies were loosely masked during the application of blackout and will have evidence of varying degrees of overspray typically around their bases.
    On page UPC 11-13 / B6, the AIM shows piece 2 as a seat assembly and piece 4 as a retainerbothretainersparts.jpg
  • Gary B.
    • February 1, 1997
    • 7064
    • Brian E.
      • May 28, 2018
      • 287
      Re: 1967 hood pins and associated retainers
      Gary, I was thinking the same thing - that the JG description casually lumped the seats in with the retainers.
      Thanks.
      • Gary B.
        • February 1, 1997
        • 7064
        • Brian E.
          • May 28, 2018
          • 287
          Understood. Thanks.
          • Mark F.
            • July 31, 1998
            • 1589
            thx,
            Mark
            • Brian E.
              • May 28, 2018
              • 287
              Originally posted by Mark Francis (30800)
              The ’67 TIMJG hood pin paragraph has been modified in response to the comments above.
              Does this mean that there is an 8th edition being written?
              • Mark F.
                • July 31, 1998
                • 1589
                Brian,
                Most TIMJGs are under a constant state of review and revision as comments come into NTLs via various communication channels:
                • emails
                • phone calls
                • in-person discussions at Meets, etc.
                • TDB posts
                • etc....
                My guess is some model years receive more comments than others, so decisions as to when, or if new editions and/or printings come out are controlled by Dave Brigham (NJC) in conjunction with his discussions with the applicable NTL (and maybe also the Board ?).
                Hope that helps !
                thx,
                Mark
                • Brian E.
                  • May 28, 2018
                  • 287
                  Brian,
                  • emails
                  • phone calls
                  • TDB posts
                  • etc....
                  Hope that helps !
                  Understood. Thanks.
                  • Gary B.
                    • February 1, 1997
                    • 7064
                    • Tony S.
                      NCRS Vice President, Director Region VII & 10
                      • April 30, 1981
                      • 993
                      Gary. You are right. On St. Louis bodies, the base piece typically shows some blackout paint near the mating surface against the hood.
                      This does not apply to AOS cars because AOS added the hood pins after blackout.
                      Tony
                      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                      Original member of the Kansas City Chapter, est'd 07/11/1982.
                      Member: 1965 and 1966 National Judging Teams
                      Judging Chairman--Kansas City Chapter.
                      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
