Steering Wheel Restoration - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 478
    Who is currently doing steering wheel restoration, specifically C1 wheels.
    Sheldon
  • Jeffrey S.
    • May 31, 1988
    • 1890
    Re: Steering Wheel Restoration
    Contact Richard Dunham, a Michigan Chapter member, who used to do these and did beautiful work. You can email him through member search on this forum.
    Jeff
    • Richard B.
      • July 31, 1981
      • 77
      Ditto on Richard 👍👍
      • Keith M.
        • January 17, 2021
        • 688
        Curious what exactly is steering wheel restoration? Pretty simple component. Thx.
        late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
        • Don H.
          • December 1, 1981
          • 1491
          The plastic on early car steering wheels cracked, broke, and wore down.
          • Keith M.
            • January 17, 2021
            • 688
            Understood. And being as the perimeter and center cap are the plastic parts... "restoration" would seem to be nothing more than replacing those?
            • Rod K.
              • 443
              The rim is plastic molded over a steel ring and would not be replaceable. Repairable (restorable) yes, but not replaceable by any feasible method. The center cap is chrome plated die cast metal, easily replaceable as it simply snaps into place on the hub of the wheel.
              • Keith M.
                • January 17, 2021
                • 688
                Thanks for those details of which I was not aware and makes my question even more intriguing to me and still unanswered. What exactly does a "steering wheel restoration" entail??? I am only asking for my own curiosity and education as I do not believe mine needs restoration.
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11334
                  Keith, This document may help you understand what is entailed on C1 wheels. C2/C3 are totally different.
                  Rich
                    • 11666
                    Rich
                    Rich,
                    Did the cracks in the plastic reappear at the end of the spokes?
                    Those cracks usually mean that the underlying weld is broken. If that isn't fixed, the cracks will come back.
                    I've been to Richard Dunham's place multiple times and talked with him extensively about wheel restoration on C1s, which is why I dare comment on them.
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11334
                      Rich,
                      Patrick, On the 2 I did, the welds were fine. On the C1 wheels the plastic always seems to crack at those 3 joints. I suspect because when made the material is very thin there.
                      Cracks did not reappear.
                      Rich
                      • Keith M.
                        • January 17, 2021
                        • 688
                        Thanks all. My inquiry was based on wanting to further my education which you have succeeded in doing.
                        Keith
