1965 headlamp install - NCRS Discussion Boards
  • John B.
    Infrequent User
    • June 30, 1988
    • 1
    What, if any, lubricant was used on the pivot assemblies for mid-year headlamp buckets? Would silicone grease be a satisfactory lubricant today?
  • Mike T.
    • January 1, 1992
    • 568
    Re: 1965 headlamp install
    John - I have no clue as to what the factory used...or didn't use...on midyear headlight pivots but I've used silicone grease and pretty sure I also used Lubriplate #105, the engine assembly grease and no problems. Not a lot used, by the way, just a light wipe.
    Mike T. - Prescott AZ.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      The factory used engine oil to lubricate the bearings. This was applied to the felt seal. Upon rebuilding many over the years, I also used a bit of grease on the pivot shafts/bearings, along with re-oiling the new felt seals.
