Spare tire lock bolt pin - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 676
    What purpose does this serve? You can see attached pics of what I have...seems to be worn to dysfunction. Found can get one at Zip...not sure where else. But why?? Wuzzit do?
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Mark L.
    • 561
    Re: Spare tire lock bolt pin
    It keeps the bolt from coming out of the bracket.
    • Keith M.
      • January 17, 2021
      • 676
      Sorry if I was not clear. I am not referencing the knob thingy (aka bracket nut) that threads ONTO the bolt and yes THAT part keeps the bolt from coming out of the bracket. I am referencing the roll pin that goes INTO the slot at the very end of the bolt. Only thing I can think of it keeps the knobby thing from accidentally spinning off the bolt...and I think I just answered my own inquiry?? Or no?
      • Paul D.
        • September 30, 1996
        • 491
        I think you did! Just keeps you from running the bolt out too far. Chip.
          • 11643
          I just used a roll pin from the hardware store to replace that pin on the end. No need to buy it from anywhere special.
          • Harry S.
            • July 31, 2002
            • 5305
            Agree with Mark. It prevents the bolt from coming completely out. It's a safety item. If that bolt comes all the way out with your hand under the tub that contains a tire it will result is several stitches when it falls on you. Don't ask me how I know, something stupid I did when I was 18.
            Also, the early pins were not rolled, they were a solid steel pin. I can not recall when the changed to a rolled pin.
              • 43221
              Harry------
              The pin was always solid steel from 1963 to 1982. GM #9420488. Never available in SERVICE.
              A roll pin as mentioned by Patrick will serve equally well and, likely, better.
