Attached is a photo of a 1970344 ignition coil bracket used on 1968-1972 models. The angle measures 25 degrees. Is the 1946538 ignition coil bracket used on 1973-1974 models similar but with a larger angle (for air cleaner clearance purposes, I assume)? If so, what is the angle?
Dave
Dave
