BLEM stamped Goodyear White lettered F70 X 15 OE Tires - NCRS Discussion Boards
  • Ralph S.
    • February 1, 1985
    • 935
    How would these be treated in Judging
  • Ralph S.
    • February 1, 1985
    • 935
    Re: BLEM stamped Goodyear White lettered F70 X 15 OE Tires
    • Harry S.
      • July 31, 2002
      • 5346
      If there is nothing in the Standard deductions, then at least 20% on the Configuration part of CDCIF on any tire with the BLEM.
      • Ralph S.
        • February 1, 1985
        • 935
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 933
          Tires are a Standard Deduct item. You can't use CDCIF on these.
          The judges would have to figure out what section of the Standard Deduct table applies to these tires.
          • Harry S.
            • July 31, 2002
            • 5346
            I just went through the Standard Deductions on tires and Joe is correct as usual. I believe the judges would select the second Deduction of 20% per tire due to the BLEM mark on the tire.
            • Leif A.
              • August 31, 1997
              • 3655
              Just a thought. Aren't cars judged in an "as delivered from factory"? No car would ever be delivered with "BLEM" tires.
              Leif
              • Ralph S.
                • February 1, 1985
                • 935
                There must be a way to smooth out and fill that in
                • Harry S.
                  • July 31, 2002
                  • 5346
                  Ralph, If it's one tire, it's 1.2 points or rounded down a one point deduction.
                  • Ralph S.
                    • February 1, 1985
                    • 935
                    I have 8 of them
                    • Harry S.
                      • July 31, 2002
                      • 5346
                      I have 8 of them
                      Tires are worth 30 points. For 5, it's a 6 point deduction. If the car is excellent, don't sweat the 6.
                      • Ralph S.
                        • February 1, 1985
                        • 935
                        What are these tires worth i want to sell them
                        • Brian M.
                          • February 1, 1997
                          • 1842
                          I would think a Tire marked BLEM would be a Full Deduct.
                          • David H.
                            • June 30, 2001
                            • 1567
                            Brian
                            "Full Deduct"? Based on what?
                            Tires are judged by Standard Deduction Guideline #3.
                            Dave
                            • Joseph S.
                              • March 1, 1985
                              • 933
                              Brian, I think if you read the 20% deduct section, that should check all the boxes for the blem sidewall issue.
