69 427 Manual Exhaust System - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 807
    Guys,
    I am in need of the above for a future flight judged car. I prefer to use Gardner and Eddie is 10 weeks out. As an alternate I can get the system that Corvette Central is offering now. My question is this, has anyone had any issues with a Corvette Central system on a flight judged car? I would buy the welded aluminum system. I know I will lose points for not going raw steel but I am willing to take that hit. Please let me know your thoughts.
    Lawrence
    • 11698
    Re: 69 427 Manual Exhaust System
    The points difference between a Gardner system and a Corvette Central system is minimal, if any. You would take the usual deductions for either one being aluminized, and only a small deduction if warranted for configuration.
    You can lose as much for the incorrect clamps and tips as you can for the rest, so pay attention to those details.
    • Mark E.
      • April 1, 1993
      • 4614
      Lawrence,
      Here's my thread on receiving and installing CC's welded exhaust:
      https://www.forums.ncrs.org/showthre...rived-(photos)
      As Patrick advises, no replacement system is exactly like the original (not double walled, no wrinkle bends are two big differences) but I am pleased with fit and overall quality. When I shopped a few years ago, only CC offered welded mufflers. That may be different now but I don't know.
      It sounds like originality is a major consideration for you. But you can upgrade the stock 1969 2" system to 2 1/2" as used in 1970-74 big blocks.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
        • 11698
        However, if the judges detect this it's an additional deduction.
        • Lawrence S.
          • April 1, 1993
          • 807
          Thanks guys.
          • Patrick B.
            • August 31, 1985
            • 2017
            Lawrence,
            • Mark E.
              • April 1, 1993
              • 4614
              I said this, but the transmission hanger bracket will need to be changed from 2" to 2 1/2"... and you'll need to research if the exhaust manifold donut connection will fit... maybe not.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
                • 43292
                Originally posted by Patrick Boyd (9110)
                I think one of the exhaust manifolds on a 70 and up big block is different from the 65-69 manifolds. You would need the 68 2 1/2” system. In case the 68 system is also 2”, then the 67 forward pipes with the 70 rear pipes with mufflers would provide a 2 1/2” system for a 69 car.
                Patrick------
                Yes, the left side BB manifold for 1970-74 was different than the 1965-69. So, when retrofitting a 2-1/2" system to a 1969 BB, one needs to use the 1968 system.
                All 1968 Corvettes were 2-1/2" systems----base engine to L-88.
